586,032 active members*
2,993 visitors online*
Results 1 to 1 of 1
    Jan 2007
    1389
    2008 vf2ss error 130
    Got a question on the manifold that runs the air.
    when you let go of the clamp button to the machine its suppose to clamp the tool fast. Mine goes up slowly, I replaces the left side Valve(solenoid ) to know avail. which is obvious now as I didnt think this through just rushed to haas and bought valve.
    both of the big lines are for more pressure.
    when I disconnect one of the big lines or one of the black lines the tool clamp works normal.
    does this mean its the smaller middle solenoid or can it be those 2 silver cans on the sides with the 1/2" air lines coming out?
    somehow the exhaust isnt releasing and I cant find any airleaks in the system.
    A pic is attached for the manifold I have. just cant find a diagram anywhere that shows what each valve and hose does.
    I replaced the exhaust stones as well.
    For those of you who think you can add a small dwell after a tool change DONT while it may help for the exhaust to release and clamp the tool.....sometimes because the machine is fast even at 5% the tool will drop then pull up and be on the lugs and STILL run.
    I found this out the hard way running a tool change at 5% luckly it was tapping a 4-40 into alum at 500 rpms. just broke the tap
    Thank you
    Delw
  1. vf3ss and vf2ss
    By Delw in forum Haas Mills
    Last Post: 08-30-2012, 01:39 PM
  2. VF2SS Error 234 Spindle Cable Fault
    By FP Racing in forum Haas Mills
    Last Post: 04-12-2011, 02:30 AM
  3. VF2SS shutting down
    By Fantail in forum Haas Mills
    Last Post: 02-02-2008, 12:34 PM
  4. okuma 2008 error. DMA transfer does not complete within a specified cycle time.
    By mikul in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 05-28-2007, 05:36 PM
  5. VF2SS Ethernet / HD / USB FIX
    By highspeedmike in forum Haas Mills
    Last Post: 04-02-2007, 07:43 PM
