586,062 active members*
4,405 visitors online*
IndustryArena Forum > MetalWorking Machines > Tree > Buying used Kira VTC30
    Oct 2015
    215
    Ive been offered a KIRA VTC30 for $1k and I'm considering it. It has two known errors with Y axis motor broken contact and something wrong with the spindle (seller it's something with "fingers"). I've only spoke briefly with the seller so not much info for now but I will get some more details tomorrow. The question here is if this is a good purchase for hobby use at home? What should I ask the seller about tomorrow when we talk more in detail about it? If I go to have a look at it what should I look out for and test?
    The two errors could that be a broken machine that I will never be able to fix? I suppose the contacts should be a easy fix but since I don't understand his description of the broken spindle I'm not sure what can be wrong with that. Is there expensive/outdated parts here that I won't be able to source?
    My only previous experience with CNC machines is a Omio CNC router and some homebuilt 3d printers and my background is PLC engineer/tech working on control systems. Out of my league to buy a broken machine?
    Aug 2012
    44
    Re: Buying used Kira VTC30
    The "fingers" might be something related to the tool changer?
    I would ask how much does it weigh? For a home shop you will want to be sure you have a pretty thick concrete floor.
    I'm guessing that unit could weigh somewhere between 8 -12k Lbs.
    What power requirements does it need?
    Also, you might pay as much, if not more for the rigging / transport charges too.
    Just a few things to consider, other than that it's a pretty nice deal for $1k if you have the means to repair it.
    Oct 2015
    215
    I asked about that and he said it was not it was related to the spindle. He just guessed tho as the spindle wasn't even starting up so it could be everything from the VFD to rusted motor due to long time without use ^^ Is it a risky buy? It's been a machine that was in use in a prison for the inmates before so it's not been under heavy use most likely.
    It weight 2500kg. I have one spot where there is 15cm thick concrete with steel reinforcement inside and another with 25cm. It's a old farm building so we drive big tractors on the floor. Not to worried about it not holding up for it but it will be a PITA to move around.
    This guy had a truck going past my place in not to long and he could prolly put in on that for not much cost. Problem is unloading it here and handling it. Really not sure how to attack that issue.
    For power, it had a 32Amp 3phase 230V contact on it. He said he thought it was 25A requirement and I got a 25A fuse to my whole garage going from my house The stepper motors will pull same current all the time but the spindle is only pulling what it's using as a regular AC motor or is that also acting as a servo motor?
    Oct 2015
    215
    Should I be able to rotate the spindle by hand when not energized or is there a break on these usually? Today I’m driving out to have a look at it still a bit clueless on what to look for ^^
  1. Maintenance og Operation manual for Kira VTC30 /Fanuc O-Mate
    By oddbear in forum Machinery Manuals / Brochures
    Last Post: 12-27-2023, 04:49 AM
  2. Need PC parameter for Kira KV-5MC
    By Donatello Tam in forum Fanuc
    Last Post: 05-06-2016, 02:51 AM
  3. KIRA FANUC 10M
    By NEOKO in forum Fanuc
    Last Post: 04-09-2010, 05:19 PM
  4. Tree/Kira VMC
    By rhinsen in forum Tree
    Last Post: 01-30-2008, 12:39 AM
  5. Chevalier vs. Kira
    By ricardog in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 12-07-2006, 10:20 PM
