586,052 active members*
3,990 visitors online*
Thread: Huanyang VFD
    Dec 2014
    46
    Huanyang VFD
    Well I have had some success getting my spindle working better with Mach3
    The actual RPM on the mill is 3 X more them the RPM in Mach3, I assume this is a parameter setting in the VFD
    Does any know which setting and how to fix it?
    Apr 2005
    1268
    Re: Huanyang VFD
    If you are using Mach 3,, then be sure and set you correct pulley ratio. Kinda sounds like that setting is wrong!
    Hope this helps.
    Bill
    PS. Sorry I don't have a Huanyang VFD so I can't speak to settings there.
    billyjack
    Helicopter def. = Bunch of spare parts flying in close formation! USAF 1974 ;>)
    Jun 2017
    32
    Re: Huanyang VFD
    I use mach 4 so what other poster said too - Check parameter / line 0144 in VFD settings for spindle max.
    Much more on this vfd here
    http://www.cnczone.com/forums/spindl...gs-manual.html
  1. E.OC.A on Huanyang VFD 2.2 Kw
    By amalejko in forum Spindles / VFD
    Last Post: 12-07-2021, 09:44 PM
  2. Huanyang VFD - again
    By sffarm in forum Spindles / VFD
    Last Post: 03-15-2017, 04:39 AM
  3. Huanyang 2.2kW VFD.
    By atc40 in forum DIY CNC Router Table Machines
    Last Post: 10-19-2014, 04:33 PM
  4. Huanyang VFD
    By dwschool in forum Mach Lathe
    Last Post: 02-06-2013, 05:40 PM
  5. Huanyang VFD
    By moonman5 in forum Phase Converters
    Last Post: 01-19-2013, 05:43 AM
