587,003 active members*
2,891 visitors online*
    Jun 2014
    1780
    1.9.12 Version Z limit problem
    I installed the 1.9.12 version of PP and had the Z limit sw lock up the program, usually a reset will let me move off the limit, in this case it wouldnt and I had to remove the limit sw to get the axis to move.
    I wonder if anyone else has had this problem or if I just did something stupid??
    mike sr
    Jul 2016
    140
    Re: 1.9.12 Version Z limit problem
    I had this happen once after a drilling cycle (I was running PP 1.9.11). I programmed the RPM way too slow (steel instead of aluminum) and lost some z steps. When the drill cycle was done, the machine tried to overshoot the retract and tripped the switch.
    Anyhow next time go into settings to disable the limit switches. Move off the switch, then re-enable them. Re-home and you should be good to go.
    Tormach PCNC 1100 Series 3 w/ Rapid Turn, Fusion 360
    Jun 2014
    1780
    Quote Originally Posted by sharmstr View Post
    Thanks for the tip!
    I saw that on the settings page I believe, never dawned on me to try that??
    I have never had any problem before, just hit reset and the table will move off the limit, this time it didnt for whatever reason with the new update, all is good now thanks..................
    mike sr
    Jul 2016
    140
    I've had it happen from time to time with every version I've run. Its just that once it was real bad and couldnt fix it via a reset. Anyhow, it should save you some time.
  1. problem with dsp and label of version 12
    By skystop in forum Commercial CNC Wood Routers
    Last Post: 07-18-2017, 05:34 PM
  2. Update Mach 3 2.62 to 3.042 version - LIMIT SWITCH doesn't run
    By EVHARTECH in forum Mach Software (ArtSoft software)
    Last Post: 04-03-2016, 01:50 AM
  3. Replies: 5
    Last Post: 06-26-2014, 12:02 PM
  4. DLL not match Firmware version problem
    By gsar10 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 11-22-2010, 10:13 PM
  5. VERSION 22: 3d Toolpath problem
    By rftools in forum BobCad-Cam
    Last Post: 10-22-2008, 01:08 AM
