586,704 active members*
2,603 visitors online*
IndustryArena Forum > CAM Software > Uncategorised CAM Discussion > Software/ Online tool to modify G-code for unidirectional 'Zig tool path'
    Sep 2017
    Hi All
    I currently need to find a way to convert a 8 bit bitmap file into G-code which is designed so that the tool path will basically be a raster (might be known as unidirectional zig tool path, I'm not quite sure as im an absolute newbie, and apologise if this was not the correct place for this thread!)
    So far I have found this online software (https://lautr3k.github.io/lw.rasterizer/) which will convert a bitmap into rastered g-code however it is bi-directional. I need my G-code to make sure my tool path is only machining in one direction, not the other!
    I tried using 'HeeksCAD' which can create pockets with a unidirectional zig however have struggled with the software with regards to importing my own BMP.
    Also have looked for G-code manipulator/editor programs but have had no luck.
    Is there any obvious/popular software which I have completely overlooked? Or maybe an easier way to do it which I have not realised?
    Any advice/help is much appreciated!!
    Jun 2005
    65
    Re: Software/ Online tool to modify G-code for unidirectional 'Zig tool path'
    i can convert it to code but will the code run your laser?
    sample of how mine does:
    g0 x0.23234 ;go to the next dot
    a0.004 ;zap it a lot
    g92 a0 ;reset the zap-0-meter
    (the laser is controlled by the step signal of the A axis)
    Sep 2017
    Quote Originally Posted by gcz View Post
    Thanks for your reply gcz, much appreciated!
    When you say you can convert it to code, in what sense? Do you mean write the code yourself?
    I think I understand what your sample does, but not sure what you mean by "zap it a lot" after a0.004?
    Jun 2005
    65
    i wrote software to do it.
    the a axis travel of 0.004 inches will produce one pulse for each uStep of the axis.
    on my mill, that's 32000 steps/inch, so 0.004 inches makes 128 pulses (zaps of the laser)
    we had a little hurricane, so i don't have power still and can't do anything till that's fixed.
  1. Converting simple DXF file to tool path G code
    By stevenSmidley in forum NCPlot G-Code editor / backplotter
    Last Post: 04-08-2016, 01:29 PM
  2. G Code Generating Unexpected Tool Path
    By jknee2 in forum Mach Software (ArtSoft software)
    Last Post: 09-03-2013, 02:21 AM
  3. How to Generate a CNC code from measured 3D tool path
    By smar in forum OpenSource Software
    Last Post: 04-02-2009, 06:51 PM
  4. CNC SOFTWARE TOOL PATH
    By RON CLARKE in forum Uncategorised MetalWorking Machines
    Last Post: 06-20-2008, 10:40 PM
