586,077 active members*
3,599 visitors online*
Results 1 to 3 of 3
    May 2011
    37
    MK3/4 power supply limit ?
    I have a MK3/4 card, the question is: in the manual card pag. 6 I read: "Use separate power supply for controller and stepper drivers.
    Controller: 8-24VDC, 200mA. "
    what limit max of power supply I can load ? from 8 to 24V, A?
    Mar 2017
    1312
    Re: MK3/4 power supply limit ?
    I think manual is clear about this. For controller you need 8-24VDC, 200mA.
    May 2015
    23
    Closer to 8V is better for the voltage regulator. 9V is a common value. 200mA as per the manual its sufficient
    Sent from my LG-D722 using Tapatalk
  1. Replies: 15
    Last Post: 10-29-2013, 12:58 AM
  2. Optical Limit Switches and USB Power Supply
    By TheBulk in forum DIY CNC Router Table Machines
    Last Post: 06-11-2011, 05:24 PM
  3. How to calculate Power supply minimum current limit
    By [Beer] in forum CNC Machine Related Electronics
    Last Post: 09-14-2010, 06:08 PM
  4. What's Causing my Power supply to Current Limit?
    By blue_steel in forum Stepper Motors / Drives
    Last Post: 11-29-2008, 10:34 PM
  5. How do I limit voltage out of a power supply?
    By buscht in forum CNC Machine Related Electronics
    Last Post: 01-05-2005, 03:03 PM
