586,077 active members*
3,736 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Dynomotion/Kflop/Kanalog > Taig CNC-Controller Replacement-Dynomotion Suggestion
Page 2 of 4 1234
Results 21 to 40 of 66
  1. #21
    May 2006
    4045
    Re: Taig CNC-Controller Replacement-Dynomotion Suggestion
    Hi Peter,
    Doesn't the power supply need to be at least 15A ... since I am using three 5A motors?
    No it doesn't. It's a power thing not a current thing. Please read this article.
    TK
    http://dynomotion.com
  2. #22
    Aug 2008
    213
    I am finally getting back to this project ....
    Tom,
    Which version of Kmotion is most current?
    KMotion434.exe or KMotion434b.exe
    It looks like I am using KMotion434b.exe on my Tree 325 build.
  3. #23
    May 2006
    4045
    Hi Peter,
    V4.35b is currently the latest test version.
    TK
  4. #24
    Aug 2008
    213
    I got one Stepper motor connected to the KFLOP/KStep (X-Axis terminal) and the power supplies on the bench. I am now ready to tune the stepper motors and I am starting with the X-axis motor on the bench.
    Here are the parameter I used and I am seeing the motor spin very smooth and, from what I can tell by the marker I am using on the shaft, very accurate when I make "Moves" in the Response Screen of Kmotion.
    Here is a screen image of the parameters I went up too.... LINK
    Attachment 432096
    To be honest, I am not sure how to tune these Stepper Motors (I have no feedback to KFLOP for graphing).
    Tom,
    Can you please fill me in on the steps for tuning the stepper motors?
    Would it be beneficial for me to add some encoders on the back-end of the steppers for feedback to KFLOP for tuning purposes?
    Below are the links to the information of all the components I am using on this retrofit to start with for reference.
    Taig CNC Machine Quick Links
    KFLOP Power Suppy
    Stepper Motor Power Supply Used
    Stepper Motor Used on Taig
    Taig CNC Machine Counter Weight Design
    Taig CNC Machine Counter Weight Design - 3D STEP File
  5. #25
    May 2006
    4045
    Hi Peter,
    There isn't any tuning involved with steppers they are open loop. It is really just a matter of finding your limitations on velocity, acceleration, and Jerk. You might read this. I see from your screen capture that you have Velocity set to 60,000 steps/sec. For a KStep with 3200 steps/rev that is 1125RPM whic is quite fast for a stepper motor. Your test plot only gets up to about half of that so you should test a bigger move size.
    Adding encoders will allow you to detect stalls and miss steps instead of just running blind. It will also allow you to recover after a fault or if the axis is disabled as the position will be maintained. It can also improve accuracy slightly as compensation for position lag can be corrected by running closed loop. Linear scales to control the actual axis position is ideal. You might read this.
    TK
  6. #26
    Aug 2008
    213
    Thanks Tom .......
    So, I am assuming, 1000 RPM is the best a stepper will do then it really does not matter what setting I have tested, as long as I am using a velocity setting that gives me 1000PRM or less.
    For my next test I used V=55000 ... which give 1031 RPM. It would seem the motor would spin faster on the bench based on the sound and rotation of the shaft I am seeing.
    However, I am not seeing any difference on acceleration until it gets lower than 250,000. Anything over 300,000 shows no difference.
    So, I am thinking these would be my setting for the 3rd order motions.
    V=44,000 (20% of 55,000)
    A=320,000 (20% of 400, 000)
    J=4e+06 (If I decrease this to 4e+05 it never reaches the top V, if I increase this to 4e+07 to 08 ... it will hit V almost instantly).
    Attachment 432116
    KFLOP Power Suppy
  7. #27
    May 2012
    537
    If Tom thinks 1125 rpm is fast id probably going going slower then 1000. Steppers really loose torque fast at high rpm. So its safer to set rapids on the slow side. Most of my problems with my old Taig would occur during rapids. Looking back now, if i cut my rapids in half it may have worked fine. I think I set my rapids at like 30 IPM. But you have a higher voltage system which should work better at higher speeds.
    Maybe on a little machine like that you could put a vise on the table and push against it (should be much stronger then you) to verify you still have some torque left at rapid speed. Just want to be sure your not on the edge, completely loosing position due to an overloaded and stalled rapid move is absolutely no fun at all. The machine will just continue going maybe several inches off from where its supposed to be, destroying parts, tooling, everything in its path, even the machine itself. I speak from experience lol.
  8. #28
    Aug 2008
    213
    Tom,
    Can I please get you to review my calculation for the KmotionCNC Trajectory Planner Perameters?
    Attachment 432162 Image LINK
    Here is the a link to the Word Doc: My Calculation for the Trajectory Planner
    KFLOP Power Suppy
    Word Doc. of my Calculation for the Trajectory Planner
  9. #29
    May 2006
    4045
    Hi Peter,
    On the bench steppers can run really fast. You really need to have them connected to the machine to see what they can actually do loaded then back down to provide a good margin. Here is a video of 4 motors running 3000 RPM with a 36V supply. But they realistically have no torque at that speed. Its also important to understand that your mechanics can have resonances that can cause stalls at certain speeds. Accelerating quickly through those speed may not cause a stall where maintaining a speed for a while may. CNC machines must be able to work continuously at any speed in their range. So I like to also check under very low acceleration to slowly sweep through all speeds as a test.
    https://youtu.be/9pqYx4g5ZcE
    Probably reasonable values. With the lower Jerk value you would reach max V if you made a longer move. If you care about making long rapid moves quickly then lower Jerk may help you move in less time. Note lower Jerk increases the move time as acceleration is applied more gradually, but if the lesser disturbances allows higher acceleration and possibly higher velocity then the overall move time may be less.
    64,000 Steps/In seems correct
    2nd order motions don't have any Jerk limiting (Jerk is infinite not smaller) and usually require slightly smaller V and A. But these are all probably good starting points.
    Note V should be entered as 0.6875 Inches/sec on the Trajectory Planner Screen (not per minute). Or maybe 0.7. It sort of bugs me when 4 digits of precision is used for a number we are basically guessing at
    HTH
    TK
  10. #30
    Aug 2008
    213
    Quote Originally Posted by TomKerekes View Post
    Hi Peter,
    ............... 3000 RPM with a 36V supply. But they realistically have no torque at that speed.
    OK ... I understand this; however, I will not be able to test on the machine for a bit as I have it apart and working with the mechanics of it with the counter weight for the Z-Axis.
    As always, this type of information is informative for me to understanding what I am looking at in the Test Response Screen/Graph in the Kmotion. I am sure you would like to think that working with the Tree J325 retrofit you helped me set-up would have given me all the experiences I need for this... I still get confused whenever I have to revisit this type of tuning.
    Cool ..........
    Yes, thank you for reminding me of this ... it was a question in my head when I was testing. Couldn't remember.....
    HTH
    Yes ... I see that now.... I was too in-tuned with making sure my math/unit conversions were correct. Thank you for pointing out the little things that can make such a big difference when things may not be working correctly.
    Single Digits on calculation approximations .... GOT IT!
  11. #31
    Aug 2008
    213
    Hi Peter,
    Since an Encoder will help me understand the tuning process with feedback, I would like to add this to the bench top testing of the tuning of the stepper motors. I understand that it will need to be re-tuned once it is mounted on the machine. Plus I will gain the advantage these encoders once i get it up and running on the machine.
    I would like to purchase one of the US Digital E6 Optical Kit Encoder for testing. I know you suggested a Linear scale encoder; however, they seem to cost more then the shaft Optical Encoders.
    Am I going to see issues with using these US Digital E6 Optical Encoders on the back shaft of the stepper motors instead of the Linear Scale Encoders?
    Would something like this encoder work with KFLOP/KSTEP?
    Attachment 432216
    Tom,
    Can you please review this US Digital E6 Optical Kit Encoder and the configuration I have selected to verify ease of comparability with KFLOP/KSTEP?
    Attachment 432218 Link to PDF Specs.
    This word Doc. holds the configuration I think I should be ordering ..... Does this look Correct?
    KFLOP Power Suppy
  12. #32
    May 2012
    537
    Quote Originally Posted by PeterTheWolf View Post
    You may not want a counterweight on the Taig. It has very fine pitch screws and its not going to fall or anything.
    To be honest, I found the weight of the head useful in eliminating backlash in the Z. The taig is terrible for backlash on all axes, and the Z axis backlash would make some parts look really bad. I would always adjust my Z axis gibs just loose enough so the head would fall and eliminate the Z axis slop.
  13. #33
    May 2006
    4045
    Hi Peter,
    Wow 300mm 5um resolution linear scale for $50 + shipping? I couldn't find the pinout but it says TTL/EIA422 (differential) so it should work.
    Yes it is compatible. Purchase the differential output because it can then be connected to either a single ended input or a differential input. KFLOP only has single ended inputs. If you have noise problems you can add differential inputs (Kanalog, SnapAmp, or 3rd party differential receivers).
    US Digital sells differential to single ended interface modules. See here.
    TK
  14. #34
    Aug 2008
    213
    Quote Originally Posted by mmurray70 View Post
    You may not want a counterweight on the Taig. ..............
    Thanks Mark,
    When running this machine off the original stepper motors/controller/power supply I was loosing steps on Z-Axis. It was set-up with MACH3 and I am was getting a loss of .060" in steps in "Z" over 8" move in "X" with a tool-path in 3D on the Y/Z plane with a stepover on "X". The Z-Axis would "kind-of" Chatter on it larger moves down in "Z" when moving fast.
    At the time I was going to retrofit it with KFLOP/KSTEP; however, you talked me into looking for a larger machine to retrofit.... which was the Tree 325J.
    Well here I am almost two years later, back on the this Taig CNC.
    I am really just retrofitting this Taig for fun and to learn more about KFLOP/KSTEP / Stepper Motors. Since now I have the Tree 325J to actually machine parts on for retrofitting.
    Once I learn enough with this project and the steppers, I would like to retrofit a old South Bend Bench Tip lathe with KFLOP. My lathe isn't are nice as the image link.
  15. #35
    Aug 2008
    213
    Hi Peter,
    Yes ... I saw that differential to single ended interface modules as well.... I will get one of these as well.
    I still have a question on the E6 Optical Kit Encoder ... What is the best suggested CPR setting (1000?) I should configure it for:
    Attachment 432272
    KFLOP Power Suppy
    Word Doc. E6 Optical Kit Encoder
  16. #36
    May 2006
    4045
    Hi Peter,
    Higher resolution is always better until you exceed the count rate of the encoder input at maximum RPM. KFLOP can conservatively accept 1 million quadrature counts/second.
    2000 cycles/rev at 2000RPM would be:
    2000 x 4 x 2000 / 60 = 266K counts/sec
    And at 20 TPI would give a resolution of
    20 x 2000 x 4 = 160,000 counts/inch (6.25ui)
    TK
  17. #37
    Aug 2008
    213
    Tom,
    I do not think I understand how I need to connect a relay to KFLOP correctly.
    I want to use the following relay to turn the 110VAC Spindle Motor on this Tiag machine on and off with M03/M05 command from the NC code / KmotionCNC.
    I have read over the manuals on KFLOP and KSTEP; however, reading and understanding electric Schematics and understanding what I am looking is still weak.
    Visuals diagrams really help me connect the "dots" .............. So, Can I please have you verify how I think this relay should be connect to KLOP?
    Attachment 432292 LINK to Word Doc. File
    KFLOP Power Suppy
    Relay Connection to KFLOP
  18. #38
    May 2006
    4045
    Hi Peter,
    OMG 8 relay driver boards for $12 with free shipping. How do they do this?
    I think your connections would likely work and could not possibly cause any damage.
    But technically it is out of specification to connect that to a KFLOP 3.3V LVTTL IO pin. Under full load of 16ma a KFLOP output is guaranteed to be greater than 2.4V. The Relay board specification claims it needs 3-5V to guarantee to turn on. The relay board also claims it needs up to 5ma to turn on. Furthermore the KFLOP IO pin you have chosen has a pull down resistor of 150ohms that consumes most all of the 16ma leaving little for something else.
    If you were to choose IO 34 or 35 (pins 15 or 16) there aren't any pull down resistors so the full 16ma would be available. Under a load of 5ma (instead of 16ma) the output would likely be higher than 2.4V but still there is no guarantee it would be 3V or higher. Most likely it would be. You could verify with a voltmeter if it actually is 3V or higher.
    Another option is to use the KStep Relay Driver Outputs. See Relay Driver Outputs here. When switching a 5V signal these will output 4V or more at up to 100ma so would easily drive the input. But it wouldn't be clear what the input would be when "off" (open circuit). The Relay board specification claims the input must be less than 1.5V to be off. if the voltage on the input is above 1.5V with an open circuit then a pull down resistor would be needed to guarantee turning off.
    Sorry for no simple answer
    TK
  19. #39
    Aug 2008
    213
    Hi Peter,
    Ok ... I purchased this Linear Scale Encoder for the X-axis and Here is the PINOUT
    Attachment 432398
    Tom, Will it be easier for me to get the Kanalog board for getting the three axis connected to KFLOP/KSTEP on this project?
    I also may add a VFD spindle motor. The Kanalog will be needed for this... right?
    KFLOP Power Suppy
  20. #40
    May 2006
    4045
    Hi Peter,
    Kanalog is required to connect to KFLOP's JP7 connector. Adding a Kanalog will require you to remove KStep from JP7 and you will lose the extra KStep IO (16 opto inputs, 2 opto outputs, and analog output). So although Kanalog adds differential inputs for the encoder, and screw terminals and other IO which would be helpful, it is probably simpler to add differential inputs some other way.
    KStep has an opto isolated analog output for this,
    TK
Page 2 of 4 1234
  1. CAM/Controller software suggestion to mill this part?
    By ConcordStud733 in forum Uncategorised CAM Discussion
    Last Post: 07-09-2013, 01:42 PM
  2. Need suggestion for Taig lathe DC motor
    By JohnnyVegas in forum CNC Machine Related Electronics
    Last Post: 10-04-2011, 06:53 PM
  3. Bridgeport series I mill using dynomotion controller
    By krz2_2000 in forum Bridgeport / Hardinge Mills
    Last Post: 04-06-2010, 08:34 AM
  4. Keling servo as Taig spindle motor replacement?
    By Hirudin in forum Taig Mills / Lathes
    Last Post: 08-18-2009, 11:41 AM
  5. Any one use a Dynomotion controller?
    By DennisCNC in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 09-09-2008, 03:02 PM
