586,075 active members*
4,127 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Dynomotion/Kflop/Kanalog > Taig CNC-Controller Replacement-Dynomotion Suggestion
Page 4 of 4 234
Results 61 to 66 of 66
  1. #61
    Aug 2008
    213
    Re: Taig CNC-Controller Replacement-Dynomotion Suggestion
    Quote Originally Posted by TomKerekes View Post
    Hi Pete,
    A following error occurs whenever the commanded Destination is different from the measure Position by more than the Max Following Error limit.
    The Enable command in the Init file:
    EnableAxisDest(0,0);
    #2 - Enable the axis setting the commanded Destination to be where the Axis happens to be with EnableAxisDest(0,ch0->Position). ......
    HTH
    Thanks Tom ... This worked... as you knew it would.
  2. #62
    May 2006
    4045
    Hi Pete,
    Thanks for taking the time to post back.
    TK
    http://dynomotion.com
  3. #63
    Aug 2008
    213
    Question: Why won't SetBit (35); in my M03_Taig.c file turn on my spindle when I run NC Code?
    It will work if I manually turn it on at the digital I/O screen.
    I attached the C-Code I am trying to run.
    Attachment 446806
    Attachment 446808
    Attachment 446810
  4. #64
    May 2006
    4045
    Hi Peter,
    I don't see the C Program.
    Is the C Program setting the bit as an output? With
    SetBitDirection(35,1);
    TK
  5. #65
    Aug 2008
    213
    Hi Peter,
    I don't know why my C-Code didn't show. But I attached the a Zip file with my three files.
    I thought the SetBit (35) should turn a bit on.
  6. #66
    May 2006
    4045
    Hi Peter,
    Cnczone doesn't allow .c files. You can add a .txt extension or zip it as you did.
    SetBit() will set a bit but it must be configured as an output first. I don't see its direction ever configured. By default bits are inputs. Add the SetBitDirection(35,1); to your Initialization program.
    TK
Page 4 of 4 234
  1. CAM/Controller software suggestion to mill this part?
    By ConcordStud733 in forum Uncategorised CAM Discussion
    Last Post: 07-09-2013, 01:42 PM
  2. Need suggestion for Taig lathe DC motor
    By JohnnyVegas in forum CNC Machine Related Electronics
    Last Post: 10-04-2011, 06:53 PM
  3. Bridgeport series I mill using dynomotion controller
    By krz2_2000 in forum Bridgeport / Hardinge Mills
    Last Post: 04-06-2010, 08:34 AM
  4. Keling servo as Taig spindle motor replacement?
    By Hirudin in forum Taig Mills / Lathes
    Last Post: 08-18-2009, 11:41 AM
  5. Any one use a Dynomotion controller?
    By DennisCNC in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 09-09-2008, 03:02 PM
