586,036 active members*
3,578 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > PlanetCNC > Connecting a spindle motor to mk3/4 board and controlling via planet software
    Hello everyone,
    I have upgraded my spindle to a 400w brushless spindle.
    I would like to connect it and power it from my planet mk3/4 control board and enclosure. Can anyone explain the way to do it in laymans terms. I have attached some pics to help explain
    This is the power supply within my enclosure
    there is something called an octocupler which I have no idea what it does but I here is a pic of it in case it is needed
    Re: Connecting a spindle motor to mk3/4 board and controlling via planet software
    Mar 2017
    1312
    You should connect output pins* of Mk3/4 controller with control inputs of your spindle driver.
    Output pin* configuration in CNC USB controller software: File/Settings/Output/Spindle&Coolant:
    ON/OFF -> Set to Pin 1
    Direction -> Set to Pin 2
    Speed (PWM option enabled below) -> Usually pin 6
    Based on the pictures that you have attached:
    MOTOR +- is where you connect your spindle motor
    Power+- is where you connect power supply for spindle driver.
    You should connect PWM pin from controller to 0-5V input of spindle driver unit.
    Check if +5V input of this unit is for motor enable (meant as ON/OFF)
    It would be very helpful to have any user manual of this unit.
  1. Connecting spindle to breakout board
    By waterrat in forum Spindles / VFD
    Last Post: 11-01-2014, 11:58 PM
  2. Connecting a breakout board to spindle speed control
    By waisberg in forum Commercial CNC Wood Routers
    Last Post: 10-25-2012, 08:04 AM
  3. Connecting motor to usb control board for rotary table
    By qmite in forum Stepper Motors / Drives
    Last Post: 09-14-2012, 09:32 AM
  4. Problem connecting spindle inverter to brakeout board C11G
    By 6bx in forum CNC Machine Related Electronics
    Last Post: 02-23-2011, 10:09 PM
  5. G 540 controlling Keling DC Brushless spindle motor
    By Praymond1209 in forum Gecko Drives
    Last Post: 11-27-2010, 02:28 PM
