586,106 active members*
3,041 visitors online*
    Sep 2017
    20
    Chinese 3040 prt-e750 controller
    I installed the Mach 3 demo because the disc they sent had an internal error b109-13. After watching the Mach 3 setup tutorials I finally got the stepper motors running by assigning them to parellel port pins. The vfd blinks 400.00 and has the stop indicator lit and will not run even in manual. If I unplug the parallel port I can make the spindle work with the potentiometer on the front in manual. Any ideas would be greatly appreciated!
    Sep 2017
    20
    Re: Chinese 3040 prt-e750 controller
    For got to mention breakout board for db25 is tx 14175
    Sep 2017
    20
    Quote Originally Posted by JoshG502 View Post
    I had it running through manual and controlled with the pot, made some practice cuts, stopped went inside and came back and CPU was off, turned back on and spindle wouldn't start.
    Mar 2016
    13
    I’m having the same issues. It was working by pushing run button but now the computer causes it to go into stop mode and that’s it until I unplug cord. I’m looking for the driver for this mess of a machine as well. Any settings would help.
    Mar 2007
    2083
    If your controller has a TX14175 breakout board that I reverse engineered to answer another post
    Mach 3 has to send the PWM signal to printer port pin1 to control the spindle speed
    and printer port pin has to be at logic 0 (0V) to switch on the relay that switches the spindle VFD to forward
    Attachment 380104
    the limited notes I have for a PRT-E1500W control box
    indicate for manual control of the spindle
    the manual/PC switch has to be in manual and
    on the VFD boards 11 way terminal block "COM" and "FWD" connected together
    (this is normally done by the relay on the TX14175 breakout board)
    Attachment 380128
    note - both diagrams need checking as some of the info is traced from photos taken of the internet
    John
    PS
    one danger I have noticed with these Chinese control boxes is
    they have used a 4 pin chassis mounted plug on the back of the control box as the 3 phase output to the 220V spindle motor !!!!
    and the same 4 pin plugs as the stepper driver outputs to the stepper motors !!!!
  1. Help ID this controller in my Chinese 3040?
    By DurocShark in forum Chinese Machines
    Last Post: 04-19-2021, 05:20 AM
  2. Replies: 3
    Last Post: 04-20-2019, 11:23 PM
  3. New to CNC, Chinese 3040
    By alstaubin in forum Chinese Machines
    Last Post: 01-23-2016, 02:30 PM
  4. Switching Controller Board on Chinese 3040 or 3020 CNC Machine?
    By ColdSpike in forum USB, RS232, PARALLEL etc
    Last Post: 09-12-2015, 05:40 PM
