586,069 active members*
3,714 visitors online*
    C axis does not follow the shorter path.
    Friends!
    We have a machine with Siemens Sinumerik 840Dsl control. There is a problem in C-axis that it does not follow the shorter path to reach the programmed destination and rotates in only one direction. For example if we program it to move at an angle of +15 degrees, it rotates correctly according to programed path and direction. But if we want to rotate it back from its current position (+15 degrees) to -17 degrees position, it rotates in + direction and reaches to 361 degrees position. Should it not follow the shorter path in reverse direction to reach the destination. Kindly help.
    Rana Ali
    Oct 2016
    Re: C axis does not follow the shorter path.
    Hello.
    Try this:
    G0 C=DC(your degrees here)
    For example:
    G0 A0 C=DC(0)
    G0 A0 C=DC(15)
    G0 A0 C=DC(345)
    The value must be positive.
  1. Haas Renishaw Probe Offset is shorter now?
    By sanddrag in forum Haas Mills
    Last Post: 03-27-2017, 03:04 PM
  2. EZ Path Follow Rest
    By Perfect Circle in forum Bridgeport / Romi Lathes
    Last Post: 03-20-2014, 01:47 PM
  3. TTS Collet Holders shorter?
    By skray775 in forum Tormach Personal CNC Mill
    Last Post: 07-09-2012, 04:23 PM
  4. What newer 5-axis machine do you use? Follow reply rules please.
    By krustykrab in forum Uncategorised MetalWorking Machines
    Last Post: 05-02-2008, 05:12 PM
  5. Pointer to follow tool path.
    By Kiwi in forum BobCad-Cam
    Last Post: 07-28-2006, 04:03 AM
