586,409 active members*
2,939 visitors online*
IndustryArena Forum > MetalWorking Machines > Knee Vertical Mills > how do you handle the knee on a knee mill?
    Apr 2017
    67
    1988 Lagunmatic 110
    LinuxCNC 2.7.0
    Mesa 5i25/7i77
    I have retrofitted this mill to Mesa/LinuxCNC from the old Dynapath Delta20 controls.
    I am wondering what to do about the knee. When I got the mill there was no motor for the knee but there was a power cord ran to that general location so I assume there used to be one on it but not sure. There is no handwheel, just a shaft sticking out. Do these knees typically have a servo on them? Or just a little gearmotor? or handwheel? Is there typically knee position feedback to the controller?
    Dec 2013
    5717
    Re: how do you handle the knee on a knee mill?
    Most knee mills have a hand crank, could have a hand wheel. Power feed is optional, but can be installed. Mine has a handwheel with a power feed. People have done all kinds of things with the knee feed from as simple as attaching an electric drill motor to the shaft to full servo under computer control. Just depends on what you want to do.
    Normally the knee position is not fed back to the controller, but it could be made to do so. Mine has an encoder on it and reads out on the DRO display, but is informational only and not active in the CNC program.
    Apr 2017
    67
    I have an old right angle gear motor I think I want to hang off it. Just need to find out if it's reversible.
    I guess it would be cool though to make it a servo axis so it could supplement z-height.
  1. Best way to mount pulley and handle on knee drive
    By brian257 in forum Bridgeport / Hardinge Mills
    Last Post: 04-26-2012, 11:06 PM
  2. Please help. Best knee mill.
    By mnemonic in forum Knee Vertical Mills
    Last Post: 10-21-2009, 07:44 AM
  3. Need knee handle for Journeyman 310
    By ken fedirko in forum Tree
    Last Post: 12-21-2007, 08:04 PM
  4. IH vs Knee Mill
    By SCzEngrgGroup in forum Charter Oak Automation Support Forum
    Last Post: 11-14-2007, 10:47 AM
  5. knee on mill will not go up
    By shannon carson in forum Bridgeport / Hardinge Mills
    Last Post: 08-16-2007, 08:50 PM
