Working Size (X Y Z) |
1300×2500×300 mm |
Driving Motor |
Servo - Brand Delta |
Controller |
SYNTEC |
Command |
G-code |
Max.Traveling Speed |
60,000 mm/min |
Max.Working Speed |
45,000 mm/min |
Work-Holding |
By vac-sorb or by clamp, both available |
Vacuum Pump |
5.5KW, air-ring, 160CBM/hour flow rate |
X Y Transmission |
Helical rack and pinion , HIWIN square linear guide way |
Z Transmission |
Taiwan TBI rolling ballscrew , HIWIN square linear guide way |
Spindle |
9.0kw , air cooling, 0-24000 rpm variable speed (HSD from Italy) |
Tool Magazine |
Linear Style, 6 position |
Tool Shank |
ISO30, 6 pieces provided for free |
Collet Size |
ER32, available diameter of cutter φ3.175-φ18mm |
Tool Sensor |
Included |
Working Power |
AC 380V/50-60Hz, 3 Ph 4 Wire |
Max.Power Consumption |
22KW |
Net Weight |
1600 KGS |
Packing
Plywood case suitable for sea shipment
