586,071 active members*
3,968 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Is it at all possible to build a metalworking CNC router out of aluminum profiles.
Page 3 of 3 123
Results 41 to 47 of 47
  1. #41
    May 2005
    3920
    Re: Is it at all possible to build a metalworking CNC router out of aluminum profiles
    Quote Originally Posted by teamloks1 View Post
    hi peter i already ask from my local distributor they only have biggest 200*200*13mm which cost 136usd per meter and 100*100*10mm 55 usd per meter is it good price you think?
    Your best bet is to convert the cost to a dollar per pound number. Obviously in a metric country that wouldn’t be pounds (in most cases). You can then compare that number to the going rates for the metal in question.
  2. #42
    Jan 2008
    1529
    Been a while since I've bought steel but that price seems reasonable, particularly if you can buy per metre (not by the whole length).
  3. #43
    Jul 2008
    9
    Hi, all.
    Can I get in on this?
    I too built an extrusion frame router and am not happy with it's stiffness. I wanted to machine Al, and it does, if you go slow. So I am going to build a new frame and move all the motion parts over. I have some Questions about how to proceed. I don't want to hijack this thread!
    Ben
  4. #44
    May 2005
    3920
    Quote Originally Posted by Mr. Ben View Post
    Hi, all.
    Ben
    Hi Ben.
    If you want some help create another thread. In this case though you just highlight a common result that people get when trying to build a router for Aluminum machining. That is a machine gets built that doesn’t mechanically meet the users needs.
    So your post offers a good point for the original poster to consider. He really needs to consider mechanical stiffness.
  5. #45
    Jul 2018
    6339
    Hello Mr Ben - Many threads in here cover upgrading routers to be able to cut aluminium. Most upgrades do not get there as the basic machine does not have the potential for the required stiffness, as you have found out. So its a start again process. If you start at the gantry most calculations take you to something like a 200x200x12mm thick aluminium extrusion or a 200x200x6mm steel section. Its better to be bigger in steel a 250x250x6mm is good. Then everything has to be scaled from that. Here's my thread on designing a router for aluminium. "Routering" actually milling light metals is quite a step up for a machine from soft materials. Peter
    https://www.cnczone.com/forums/austr...ml#post2337406
  6. #46
    Feb 2019
    91
    hi Peter do you have your router design for sale?
  7. #47
    Jul 2018
    6339
    Hi Loks - Pricelist is here thru link at bottom of page. https://cncrouterkits.com.au/maximus...ty-cnc-router/ Peter
Page 3 of 3 123
  1. Aluminum router build - Could use some input
    By Tumblebeer in forum DIY CNC Router Table Machines
    Last Post: 06-26-2014, 01:52 PM
  2. New Machine Build - Router for aluminum
    By pupetxls in forum DIY CNC Router Table Machines
    Last Post: 05-28-2014, 03:14 PM
  3. need to build a cnc router / mill for aluminum
    By axkiker in forum DIY CNC Router Table Machines
    Last Post: 07-30-2013, 07:36 AM
  4. 24 X 72 X 5 Aluminum Router Build - Need Advice
    By BigSmith in forum DIY CNC Router Table Machines
    Last Post: 02-01-2011, 06:02 AM
  5. New Build - Aluminum Router Table - 2' x 4'
    By wwendorf in forum DIY CNC Router Table Machines
    Last Post: 05-05-2010, 09:41 PM
