I run a Mori Seiki SL25 with a Fanuc 15T control, I often have to make short parts between .5 and 2" long from long stock, I'll hang as much stock as possible out of the chuck and then make and part-off as many part's as I can without pulling out more material, I've just been using the Input+ key to shift over the #00 Shift offset and make a new part, is there an easy way to automate this process other than using subprograms and G55/G59 offsets?
