586,089 active members*
3,755 visitors online*
Thread: Correct VFD
Results 1 to 5 of 5
    Apr 2011
    21
    Correct VFD
    Hello Guys
    I have a Wasino CNC lathe that is rated at 2.2Kva and I only have single phase 220 in my shop. I need to know what size VFD would work with this lathe. Thanks in advance for your input.
    15362
    Re: Correct VFD
    Quote Originally Posted by Bertman1 View Post
    Hello Guys
    You would need at least a 3Kw VFD, and capable of using a Braking Resistor, larger the VFD for a lathe the better, usually go by the spindle motor Hp, you want the VFD to be at least 2Hp larger than your lathe motor
    Mactec54
    Apr 2011
    21
    Re: Correct VFD
    Thank you for the information, what is a good manufacturer
    Apr 2011
    21
    Re: Correct VFD
    I have a Huanyang 10HP VFD and it keeps kicking the vfd off, I have a rotary phase converter but was told that if I hook it up to the CNC it would blow the computer in it and this VFD keeps kicking out
    15362
    Re: Correct VFD
    You can only use a VFD to power the Spindle Motor, it can not be used for any other electronics or to supply power to any other part of the machine, a VFD can only supply Power to a 3 PH AC Motor
    Mactec54
  1. CAN'T GET DEPTH CORRECT
    By viper1753 in forum Mach Mill
    Last Post: 08-11-2014, 10:50 PM
  2. Correct Pay??
    By j-radkemachine in forum Employment Opportunity
    Last Post: 11-12-2012, 02:37 PM
  3. How do I know what I have is correct?
    By mousejunkie in forum Joes CNC Model 2006
    Last Post: 12-27-2011, 08:32 PM
  4. Is this formula correct?
    By widgitmaster in forum CNC Machine Related Electronics
    Last Post: 01-13-2007, 06:39 AM
  5. Are these assumptions correct?
    By Ubarch in forum Community Club House
    Last Post: 02-01-2005, 05:55 PM
