Originally Posted by
thesaent14
i am using a toshiba loptop and when i am joging my machine my xylotex motor start to scream when i use a pc i have no problem moving the motors i have notice my pulse frequency is moving lots of difrent numbers on the loptop on the pc is fix to 25837 how can i just fix this problem thanks for your help
What is happening is that something, such as Quicktime is interferring with the pulse train. You basically need to remove as many applications that run in the background that you can.
There is also an issue with some laptop types that Mach will not run on.
Cheers,
Peter.
Homann Designs - http://www.homanndesigns.com/store
