587,047 active members*
2,525 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Centroid CNC Control Products > Query - anyone out there retrofitted any other controller on Multicam routers ?
Results 1 to 5 of 5
    Nov 2013
    152
    Hi all
    Just a query has anyone out there ever retro fitted a fanuc controller (or any other make ) to a multicam router.
    The standard controllers are pretty notchy while transiting through a 3-D arc and I am reliably informed that there is nothing that can be done to improve the motion.
    I was just wondering if it`s cost effective to upgrade or would it be cheaper to just buy a machine that uses a better quality controller ?
    Thanks in advance
    Dec 2013
    5714
    Re: Query - anyone out there retrofitted any other controller on Multicam routers ?
    How about upgrading the controller for free (well almost) You still have to buy the hardware, but I'm giving away the software for now. It is running very successfully on 4 machines at this time with full 4 axis profiling capability. Will digest millions of lines of G-code with deep look ahead for smooth motion.
    Upgrading a MultiCam should be pretty easy, the ones I have worked with are all step & direction with the loop closed at the servo drive rather than the controller. I have also seen MultiCam machines with open loop steppers. Either way it should be pretty easy, very basic machines.
    Nov 2017
    7
    Hi Jim, I have a Multicam M3000, stepper drives, 2001 year that the control board is bad,can you tell me about your controller,I am looking at the acorn but not sure.
    Dec 2013
    5714
    Quote Originally Posted by bishopplastics View Post
    Acorn would be a good fit for a stepper driven M3000, a rather easy and inexpensive retrofit.
    My system is a bit more complex and expensive. The software is free to anyone who can use it, but The Galil controller that is the heart of the system can be a bit pricey. The base price of a 4 axis Galil DMC-4040 controller from Galil is $2500. You can buy these on eBay for about $200 and up, and I have no problem buying used Galil controllers from eBay vendors because the Galil controllers are very robust.
    My system is more flexible than the acorn, and in my opinion more user friendly from an operator standpoint. Custom options can be added with minimal pain. The really nice thing about my system is that there are two physical buttons, an E stop, and an Enable. Everything everything else is done with a mouse click on the screen, or from the keyboard. Also supports a touch screen. Runs on Windows 7/10/11, not much of computer is required. I prefer the mini computers, about 6x6x2 inches. Fits nicely in a control cabinet.
    Either system is a dramatic step up from the MultiCam system, which uses the most convoluted interface I have ever seen.
    Here is a screen shot of my software that is running on my mill.
    Jim Dawson
    Sandy, Oregon, USA
    Oct 2007
    43
    We retrofitted a multicam mg, with centroid software. works great
  1. dsp controller query
    By Peruanzon in forum Chinese Machines
    Last Post: 05-24-2016, 09:13 PM
  2. CAN-BUS(Controller Area Network-BUS) in CNC Routers
    By Roctech-Cathy in forum Roctech CNC Routers
    Last Post: 04-21-2015, 04:56 AM
  3. multicam controller repare or replace?
    By daisydog in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 02-02-2014, 03:32 PM
  4. New Speed Controller for Routers
    By arturod in forum News Announcements
    Last Post: 08-14-2007, 07:01 AM
