586,069 active members*
3,592 visitors online*
    401 alarm (VRDY OFF)
    dear All,
    I've puma 6s with fanuc 0T, i've lost the parameters, and i've loaded it manually but i found the machine still not ready and the alarm "401 servo alarm (VRDY OFF)" could any one help me on this.
    best regards,
    Islam
    Oct 2006
    586
    does it come up when you turn the machine on and wont let you do anything
    individual who perceives a solution and is willing to take command. Very often, that individual is crazy.
    yes it appears at the start and nothing work, no hydraulic, even the mode selector switch do not work, while changing the mode MDI always appears on the screen
    Islam
    Oct 2006
    586
    Quote Originally Posted by sting View Post
    Islam
    ok let me do some looking but i can at least get you up and going, turn it on in the back go to the control hold down P and cancle at the same time then turn it on and power it up that should get you going you will have to do this every time till you figure out what param. to change or reset i will look into that
    24221
    It sounds like the PMC is not running? or there is power missing to the operator panel?
    can you look in the diagnostics and see if any inputs change when you operate push buttons etc and the function selector switch.
    Al.
    Albert E.
  1. Not Ready and VRDY Errors
    By brgrii in forum Fanuc
    Last Post: 05-27-2014, 10:38 PM
  2. 115 P/S Alarm
    By VMC_Jeff in forum Fanuc
    Last Post: 03-17-2007, 12:02 AM
  3. 205 p/s alarm
    By bink in forum Fanuc
    Last Post: 12-09-2006, 04:04 AM
  4. alarm #180
    By j-radkemachine in forum Haas Mills
    Last Post: 07-20-2006, 07:34 PM
  5. Alarm 160
    By quatturbo in forum Haas Mills
    Last Post: 02-26-2006, 07:27 PM
