586,260 active members*
2,875 visitors online*
Thread: Macro M06
Results 1 to 13 of 13
    Sep 2015
    68
    Macro M06
    Hello,
    I have the machine Matsuura MC-600V Yasnac MX3.
    Please support for me Macro M06 to auto position ATC. ( G91 G28 Z0. )
    I am install #6130 to 6, #6073 D4 to 1 and program O9001.
    MDI mode : M06 input and press start it alarm 182 SEQ ERROR.
    It can not call program O9001.
    Thankyou.
    Feb 2006
    1792
    Re: Macro M06
    On fanuc, storing 6 in parameter 6071 would make M06 call program 9001 as a subprogram, equivalent to M98 P9001.
    Sep 2015
    68
    Re: Macro M06
    Quote Originally Posted by sinha_nsit View Post
    This machine Yasnac control MX3 Matsuura MC-600V.
    I need M06 call 9001.
    Please support for me.
    Thankyou.
    Feb 2006
    1792
    Re: Macro M06
    Don't you have any machine manuals?
    Sep 2010
    1230
    Re: Macro M06
    Quote Originally Posted by VECKT View Post
    Hello,
    Thankyou.
    Hello VECKT,
    You have the parameters set correctly.
    Alarm 182 is Sequence Error 2 and I don't believe that relates to being able to, or not, call a Macro Program. Post a copy of your O9001 program and the syntax of your use of M06 in a Tool Change Block.
    As a test, you could do the following.
    1. Execute the following Block:
    G65 P9001
    2. Save your existing O9001 Macro Program and replace it with something like the following and Call it using M06:
    O9001
    M00
    M99
    The first option will confirm if the Program O9001 can be called by a normal Macro Call. Depending on the structure of O9001, you may have to include an argument for "T" to be passed to the Macro. In that case, the sample Call Block will be something like the following:
    G65 P9001 T01
    Posting a copy of your Tool Change Macro (O9001) for the Forum to see will allow members to confirm if an argument needs to be passed and help get you better information.
    The second option above will prove if program O9001 is being call and if there is an issue with your original example. The example O9001 above contains nothing that will raise an alarm. All that should happen is that the program will halt and the Feed Hold indicator illuminated. When this happens, another press of the Cycle Start button will have the program complete.
    Regards,
    Bill
    Sep 2015
    68
    Quote Originally Posted by angelw View Post
    Hello VECKT,
    G65 P9001
    O9001
    M00
    M99
    G65 P9001 T01
    Regards,
    Bill
    I need call M06 to O9001 macro.
    O9001;
    M5;
    G91 G28 Z0.;
    M9;
    M19;
    M06;
    M99;
    I am #6130 to 6. #6073 D4 to 1.
    After I am call M06 it alarm 182.
    I can not call O9001 macro.
    Thankyou
    Sep 2010
    1230
    Re: Macro M06
    O9001;
    M5;
    G91 G28 Z0.;
    M9;
    M19;
    M06;
    M99;
    Thankyou
    Hello VECKT,
    You will have to do somethings to work through this. From your previous Post, it seems you have the M Code registered correctly in parameters. I would suggest doing as I stated in my last Post and see if you're able to call the Tool Change Macro using the following Command Line:
    G65 P9001
    Also, a Tool Number is not being passed to the Macro program and there is no reference to a Tool Number in the Macro, so it seems that this Macro simply swaps the whatever tool is in the ready position to the Spindle.
    What type of Tool Changer does your machine have? Is it an Umbrella style, where the tools must go back to the pockets from whence they came?
    Post the part of one of your programs where a particular Tool is to be called and moved to the Spindle.
    Regards,
    Bill
    Sep 2015
    68
    Re: Macro M06
    Hello VECKT,
    G65 P9001
    Regards,
    Bill
    Hello,
    MDI mode : G65 P9001 input and press start It alarm 020 prog error ( G )
    Please supprot for me.
    Thankyou.
    Sep 2010
    1230
    Re: Macro M06
    Hello,
    Thankyou.
    Hello VECKT,
    This error indicates that an Unusable G Code, or a G Code not included as an Option has been programmed. This means that your control doesn't have the User Macro Option.
    Are you able to find and display a Macro Variable Page?
    Regards,
    Bill
    Sep 2015
    68
    Re: Macro M06
    Hello VECKT,This error indicates that an Unusable G Code, or a G Code not included as an Option has been programmed. This means that your control doesn't have the User Macro Option. Are you able to find and display a Macro Variable Page?Regards,Bill
    Hello Angelw,This machine alarm AMGC RAM ERROR ( NO GENERATION ). Matsuura MC-600V yasnac MX3.Please support for me.Thankyou very much
    Sep 2010
    1230
    Re: Macro M06
    Hello VECKT,
    Are you saying that Alarm 20 is a RAM ERROR? I can assure you that, in the context of your Post #8, Alarm 20 is as I stated in my previous Post; please see the attached picture which is a screen shot of an extract from an MX3 Manual. On the basis of that, it would seem that your control is NOT equipped with the User Macro function. To go forward, you should confirm if your machine has, or has not, the User Macro function. One method of doing this is to see if a Macro Variable Page can be displayed.
    It is difficult to give you the support you seek if you don't answer the questions put to you.
Name:	MX3 Error 20.JPG
    Regards,
    Bill
    Sep 2015
    68
    Re: Macro M06
    Hello VECKT,
    Regards,
    Bill
    Hello,
    Can you help me for macro M06 to call auto zero Z0. change tool position.?
    I will pay for you.
    Thankyou.
    Mar 2018
    45
    Re: Macro M06
    I lost my parameter list and data in matsuura mc600vf due to power lost.Can any one provide me a backup.it really help ful please contact me on.I pay your charge.
    Thanking you.
    [email protected]
  1. FANUC MACRO COMPILER / Macro executor
    By ker2008 in forum Fanuc
    Last Post: 10-27-2020, 10:36 PM
  2. Replies: 2
    Last Post: 12-19-2012, 01:28 PM
  3. Replies: 3
    Last Post: 02-13-2012, 07:20 PM
  4. Replies: 2
    Last Post: 03-27-2009, 09:15 PM
  5. Convert Fanuc Macro to Fadal Macro
    By bfoster59 in forum Fadal
    Last Post: 11-09-2007, 06:41 AM
