I have a homemade machine using Mach3 and an old XP with a parallel cable. The first thing I noticed was my auto zero touch off pad didn't make a connection to stop the downward Z travel. Then I noticed my Ref All didn't move when pressed. Upon investigation, the machine coordinates reset to 0,0,0 without the gantries moving. Next I hooked up a laptop I use on my metal minimill and it did the same thing. Also, it kept changing the input signals as to high/low settings. I'd fix it so the reset button would be happy, then random settings would turn yellow and it would change on me. So I went back to the XP and noticed that none of the limit switches activated at all anytime. So I opened up my control box to see if anything was amiss. I do have 36vdc and all the wires seemed tight. I sounds like a stray signal or power supply wavering, but I don't know where else to check. The breakout board is lit, but maybe it is dying. What should I replace or check next? It actually ran part of a 1+ hour program without faulter, but then suddenly quit.
