Originally Posted by
Pj3r
I'll try to keep this short, English not being my primary language.
Last week, everything worked, had to repair the hydraulic actuator for presetting the tool in the correct position for the tool-arm (vertical ATC, side of machine).
This week, the spindle indexes, but the Z doesn't travel up at all..
There is a tool pre-set (in the switching position).
The spindle keeps indexing until I press "reset" on the program.
Seems to me that the program is stuck in whatever it is stuck in, and won't procees to the next step (or it has missed a step).
However, I can't access parameter 220-499.
Parameter 0010, bit 5 is set to 0.
PWE=1 doesn't reveal anything, but allows me to edit parameters.
I've tried various O9000-series programs but to no avail; I can't find the macros of this machine.
Currently, the program I'm using to switch tools is as follows:
O0006;
T1;
M6;
M30;
The T1 and M6 are on seperate lines to test if they should be. Doesn't make a difference.
Is there a way for the 0m to view all programs in a list-format (like with the 0i), or is it too old for that?
Is there a way to see what macros are made (for specific M codes)?
Is there a way to see parameter 220-499?
I've made 2 videos of this situation, links below.
Any help would be appreciated! (A pdf of a proper manual would be prime to start with)
EDIT; forgot a bit of info
