586,315 active members*
3,254 visitors online*
IndustryArena Forum > WoodWorking Machines > Commercial CNC Wood Routers > My Multicam is ignoring my max depth
Results 1 to 3 of 3
    Sep 2017
    Hello all,
    I'm a brand new member, and have only been running a CNC machine for a little over 2 years now. The company I work for has a Multicam MG Series. While running some acrylic today, the machine spontaneously began cutting well below the max depth set; and not by a few thousandths, but like a quarter inch into the bleeder. I've re-started, and re-homed the machine several times, and re-calibrated, then re-touched surface and max depth, but the problem persists. Any help would be greatly appreciated.
    Sep 2017
    78
    Re: My Multicam is ignoring my max depth
    Quote Originally Posted by KevinMakesStuff View Post
    Hello all,
    Check your Z axis drive belt. The cogged belt may need replacing.
    Dec 2007
    118
    Make sure the bit is not slipping in the collet.
  1. mach-3 ignoring my origin. goes to home instead
    By mxpro32 in forum Mach Mill
    Last Post: 08-09-2018, 06:28 PM
  2. VF2 ignoring M00
    By dingo0722 in forum Haas Mills
    Last Post: 04-11-2012, 01:43 AM
  3. Replies: 2
    Last Post: 02-04-2012, 05:27 PM
  4. IGNORING CERTAIN CODES?
    By GRANDPA in forum NCPlot G-Code editor / backplotter
    Last Post: 01-30-2008, 01:29 AM
  5. Ignoring Feed Speeds
    By xichanceix in forum DeskCNC Controller Board
    Last Post: 12-18-2007, 03:55 AM
