chart of achieving desired goals
hello all i have seen this chart a few years ago, and i would like to share the idea behind it with you.
the straight line represent the desired journey, so to reach a goal
the desired goal is never reached as it was intended, because of the journey
when conditions are favorable, even if the journey had a few obstacles, the reached goal is pretty similar with the desired one ( this is the 1st curved line on the chart; it is located prety close to the horizontal line, and the circles are pretty similar )
when conditions are not favorable favorable, the journey may deviate to an entire different goal, on an entire different path ( the 2nd line, leading to the rectangle )
idea behind it is that in most cases, the conditions are not favorable, and their power simply consumes the resources available for the journey.
when i 1st saw this chart, it was about the fact that being defensive consumes much more resources than being able to develop, and in most situations, the people must behave defensive, and their goals are a result of a journey with considerable obstacles, which deviates them from their purposes.
i shared this chart, so you to ask yourself if where are you know, is it your choice ? do you like it ?
