586,111 active members*
3,202 visitors online*
Thread: Sink marks
Results 1 to 6 of 6
    Sep 2017
    3
    Sink marks
    Pls give your expert opinion on the attached query for sink mark.
    Even though it looks like a very basic question but we need to provide answers to the younger generation that yes sink comes in the rib area because ... waiting to hear from you all
    Kripal
    Apr 2004
    5737
    Re: Sink marks
    If this is in a casting, it's because of metal shrinkage. Expect to find porosity in those areas as well, since there's no feed for the metal to draw from as it cools, so it will draw from small pockets of molten metal. The fix is to add some sprues or risers there, that have a larger cross-section than exists in those intersections.
    Andrew Werby
    Website
    Sep 2017
    3
    Quote Originally Posted by awerby View Post
    Thanks for the reply Awerby.
    The section in question is for a injection molded plastic part.
    Apr 2004
    5737
    Re: Sink marks
    It's still due to shrinkage, although plastic doesn't behave exactly like metal - it won't develop porosity like metal does.
    Andrew Werby
    Website
    15362
    Re: Sink marks
    Quote Originally Posted by kripal View Post
    Kripal
    On the outside of the part you get a uniform cooling, for the rib that will always get a sink if it is designed like you have it, to reduce the sink you need to have the rib a max thickness of 60% of the main body wall thickness
    Mactec54
    Sep 2017
    3
    Re: Sink marks
    Plastic will always tend to flow along the path of least resistance. Therefore, the area of the nominal wall thickness will fill up first as the plastic is injected. Only after this section is full and the cavity pressure rises will the plastic then start to fill the rib section. This can create a surface blemish since some of the plastic has had a chance to cool while it was filling the wall section. This cooler plastic may push against the cavity side and create some cosmetic blemishes, especially on textured surfaces.
    Is this analysis in right direction ?
  1. Need to know about Mitsubishi EA8 die-sink machine
    By sunshineyos in forum Waterjet General Topics
    Last Post: 02-09-2023, 02:17 AM
  2. CNC Counter Sink
    By FoxCNC1 in forum MetalWork Discussion
    Last Post: 08-12-2017, 06:43 PM
  3. Kitchen sink
    By berzer in forum Moldmaking
    Last Post: 04-22-2013, 08:04 AM
  4. Source for heat sink
    By TarHeelTom in forum Gecko Drives
    Last Post: 05-17-2010, 02:33 AM
  5. Sink EDM Kit
    By djauregu in forum Want To Buy...Need help!
    Last Post: 04-01-2008, 11:45 PM
