586,106 active members*
2,978 visitors online*
IndustryArena Forum > MetalWorking Machines > Cincinnati CNC > Umbrella tool magazine- wrong tool change in middle of program
    Sep 2017
    10
    Hello everyone, I have a Cincinnatii DART 500 from 1998 with Acramatic2100. There was a problem with the wrong tool in the cycle. The machine worked first with the T4 tool, then T5, T2, T7 when it was command T3M6 machine grabs T4 what did not work out well. The problem is that all previous tools were grabs well. The mistake came in the middle of the cycle.
    Did any of you already have a similar situation?
    Best regards,mutex/ocfipreoqyfb/mutex
    Dec 2006
    584
    Re: Umbrella tool magazine- wrong tool change in middle of program
    You have a once per tool prox switch which keeps track of the tool number after alignment. You my have an intermittent switch that is need of adjustment.
    MIKE CNC Machine Services INC | Cincinnati Milacron MachinesCNC Machine Services
    Oct 2011
    205
    Yep, I had this exact problem. Had a piece of crap on the prox switch.
    Sep 2017
    10
    Thanks for the answer! The most interesting thing about this is that the machine made about 200 cycles before it happened.
    The mechanic showed me what would happen when the sensor was too far from the mechanizm. Machine immediately shows alarm.
    Best Regards,
  1. Umbrella sticking on return after tool change
    By alphaorange1 in forum Daewoo/Doosan
    Last Post: 08-31-2017, 08:34 PM
  2. MIT 320 UMBRELLA TOOL CHANGE
    By richard booker in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 04-10-2012, 06:49 PM
  3. Auto tool changer-Umbrella type tool magazine.
    By maylin1105 in forum News Announcements
    Last Post: 02-15-2012, 03:38 AM
  4. Program tool pot select on an umbrella?
    By calgarykevvy in forum Okuma
    Last Post: 12-05-2010, 12:18 AM
  5. Tool Change Recovery VF3 Umbrella
    By cncmaintenance in forum Haas Mills
    Last Post: 11-07-2008, 07:05 PM
