586,082 active members*
3,459 visitors online*
IndustryArena Forum > MetalWorking Machines > Bridgeport Machines > Bridgeport / Hardinge Mills > Bridgeport Interact 412 Fanuc Controller Memory Issue HELP
    I have a Bridgeport Interact 412 with a Fanuc OM controller on it.
    I have loaded several smaller test programs (about 20K) using DNC Precision software from my PC, but if I try to load something like 270K, I get an alarm right at the point 80K has been loaded.
    I either get an 087 alarm which indicates it is waiting for a handshake signal...OR if I turn off all handshaking I get an 070 alarm at the same point when 80K is loaded.... 070 indicates insufficient memory.
    In my parameters page, parameter 901 is set to 120M.
    Any suggestions? At times it seem like a handshaking issue, but I have played around with adding a long delay (500ms) between each line and I don't get a handshaking alarm but I do get the memory alarm.
    I appreciate any help you can offer.
    Jan 2013
    8
    Do you have a copy of the Parameters and PC Parameters ?
  1. Bridgeport Series 1 Interact (TNC 145C) - spindle issue - HELP!
    By alexyates in forum Bridgeport / Hardinge Mills
    Last Post: 07-13-2015, 12:56 PM
  2. Bridgeport Interact 421 - Fanuc O-mate M Controller - 101 P/S Error?
    By CNC-Joe in forum Bridgeport / Hardinge Mills
    Last Post: 04-03-2012, 03:07 PM
  3. Bridgeport Interact 720 memory problem!
    By FLjoyride in forum Bridgeport / Hardinge Mills
    Last Post: 10-29-2010, 01:35 AM
  4. Bridgeport Interact 412 MPG Issue
    By smirob in forum Bridgeport / Hardinge Mills
    Last Post: 07-15-2008, 02:27 AM
