586,080 active members*
3,925 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > Complex Pocket shapes...bobcad not getting the right shapes to pocket
Results 1 to 6 of 6
    Oct 2007
    446
    Question Complex Pocket shapes...bobcad not getting the right shapes to pocket
    I have complex paths i want to run a pocket op on ..but bobcad is only getting the inside shapes and not inbetween the paths like i want...
    see attached image
    tried picking paths in different order, no luck.
    Any ideas on how to get bobcad to read this properly?
    Jun 2008
    1838
    Re: Complex Pocket shapes...bobcad not getting the right shapes to pocket
    Quote Originally Posted by airbrush View Post
    see attached image
    First of all what version and build number of BobCAD are you using.
    If I am understanding this correctly the areas currently shown with toolpaths in them you want them to not have toolpaths, is it the main shape you want to pocket and leave the inner shapes uncut ?
    If yes then chain select the outer shape for a pocket and then select the inner shapes as islands
    Better if you can upload the BobCAD file (In a Zip file), makes for easier understanding.
    Regards
    Rob
    Oct 2007
    446
    will try again...that is how i did it and then tried in reverse..both same result
    Oct 2007
    446
    ok..think i found the problem...chain selected and noticed it didn't select the whole path...zoomed into the ends and found a small gap...will connect up and try again..
    Jun 2008
    1838
    You looking for something like this ??
    Oct 2007
    446
    once the path is connected up i bet it will work...haven't had a chance to try yet
  1. Losing steps when cutting splines and complex shapes
    By i_am_joe in forum DIY CNC Router Table Machines
    Last Post: 10-15-2015, 12:16 AM
  2. about precision on complex shapes
    By deadlykitten in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 06-15-2015, 08:40 AM
  3. about precision on complex shapes
    By deadlykitten in forum Linear and Rotary Motion
    Last Post: 06-15-2015, 08:37 AM
  4. about precision on complex shapes
    By deadlykitten in forum CNC Machine Related Electronics
    Last Post: 06-15-2015, 08:35 AM
  5. Complex shapes for CNC. Can this be done in polygonal meshes?
    By jininjin in forum Uncategorised CAD Discussion
    Last Post: 10-24-2013, 01:47 PM
