586,089 active members*
3,965 visitors online*
Page 1 of 2 12
Results 1 to 20 of 21
    Nov 2005
    5
    deep drilling tool needed
    I am looking for an insertable drill to cut .531 to a depth of over 4.600. I can only find a insertable spade drill, but I have used them before, and I don't think it will be rigid enough. I am only cutting t-6 alum. but I want (need) speed.
    Any help would be great!
    Buddy
    p.s. my company is cheap as hell when it comes to spending the $$, so having one made is out of the question.
    Mar 2006
    2712
    Buddy, If you have the spindle speed capability to use them, some version of gun drill should do the job. I cut similar holes in one pass 10" deep 40 years ago. You can use a "speeder" such as sold by BIG which also introduces coolant thru the spindle at high pressure to flush out chips. This set-up works fine on ductile iron also. DZASTR
    DZASTR
    Jun 2006
    478
    Bijur makes a nice product but realy 4.6" isn't all that deep hss drill with a high speed peck cycle would do it, OR you can try Iscar's chamdrill line.
    AJL
    927
    Buddy,
    CJT makes a .5312 standard..
    Here:
    http://www.cjtkoolcarb.com/catalog/K...0/style170.htm
    927
    Oops Sorry I missed the "insert-able" part of your post..my mistake..
    Nov 2005
    5
    Quote Originally Posted by ajl6549
    AJL
    The iscar chamdrill line only goes to 8X dia. That only gets me to 4.25 deep. Other then that, the chamdrill is what I am looking for.
    Buddy
    Nov 2005
    5
    Quote Originally Posted by wms
    Buddy,
    Here:
    Who sells CJT? Is is sold independently or are they sold thru a supply co.?
    927
    MSC stocks them..page 103 2005/2006 book..
    927
    Buddy,
    Just looked Kennametal makes a 10x insert drill body..
    Here: http://www.kennametal.com/en/new_cat...equestid=72761
    Then search: KSEM10XD ROUND SHK
    Then click on the link:KSEM0531R10SS075
    Good luck.
    Jun 2006
    629
    Can I ask, why are you limiting yourself to Insert Tooling?
    "It's only funny until some one get's hurt, and then it's just hilarious!!" Mike Patton - Faith No More Ricochet
    Jan 2006
    4396
    Arrow Seco Carboloy
    Seco Carboloy has a new line of insert type and insert spade drills. You may want to check out their website www.carboloy.com
    Toby D.
    "Imagination and Memory are but one thing, but for divers considerations have divers names"
    Schwarzwald
    www.refractotech.com
    Jul 2004
    35
    OSG and Titex both offer carbide, coolant fed, deep hole drills up 30XD. If you have a high RPM spindle with good through the spindle coolant pressure, these things can really fly.
    hss or a carbide tip drill is sufficient why pay the big bucks to drill a simple hole that is by no means deep especially aluminum , start the hole with a stubby then fly with the longer drill
    Jul 2006
    9
    Actually there are a whole lot of factors when considering what type of drill to attack your application with.
    First off, I'd like to thank wms for the referral . Unfortunately, the series 170 isn't necessarily the best bet for low silicon (gummy, stringy crap) aluminum because the straight flute lacks a positive rake angle at the cutting edge and has a problem breaking a chip in that type of material.
    Some things to consider when picking a drill: What type of machine are you on? How much coolant pressure are you working with? And a big one - How many parts are you producing? Is it one 500 piece run, or will you be making 10,000 a week for the next 5 years?
    Jan 2006
    4396
    Check www.carboloy.com you don't want a "Spade Drill" you need an "Indexable Insert Drill" like this one
    http://www.secotools.com/upload/nort...fo%20Promo.pdf
    I didn't do the research for your tool size but here is the PDF.
    Toby D.
    Schwarzwald
    1880
    I have been using both spade and indexable for years and while the High end is typicaly Insert drill territory I wouldn't hesitate to use one (spade drill) for an application like this. Although for that matter a cobalt drill with the proper tip would probably work as well. but as the previous post said You really need more information.
    Why did you quote jct in your post a 170 like he is talking about isn't a spade drill and he stated that he wouldn't neccessarily pick that drill for alum???
    thanks
    Michael T.
    "If you don't stand for something, chances are, you'll fall for anything!"
    Mar 2006
    1625
    Quote Originally Posted by Jay_At_CJT
    ... Some things to consider when picking a drill: What type of machine are you on? How much coolant pressure are you working with? And a big one - How many parts are you producing? Is it one 500 piece run, or will you be making 10,000 a week for the next 5 years?...
    and can you go in with a pilot drill just to open up as deep as you can or can you flip part and go from both sides?
    i don t get it ,its a small hole in aluminum
    1880
    inexperience!
    give him time, he will be drilling 10x dia in no time!
    thanks
    Michael T.
    Apr 2005
    1194
    Take a look at Allied spade drills. They use a 8620 shank that is plenty tough for what you need and they have lengths you wouldnt believe. If you have spindle through coolant you can make ultra short work of that type of job
Page 1 of 2 12
  1. Deep Hole drilling, really deep...
    By GM81 in forum Fadal
    Last Post: 11-25-2013, 10:57 PM
  2. Deep Drilling?
    By hugh jass in forum MetalWork Discussion
    Last Post: 11-01-2013, 03:09 PM
  3. Deep hole drilling
    By kalmah in forum MetalWork Discussion
    Last Post: 02-27-2013, 11:17 PM
  4. Drilling Deep
    By ALLtra Mach in forum MetalWork Discussion
    Last Post: 10-06-2008, 04:43 PM
  5. deep drilling 2mm holes
    By kesparate in forum Uncategorised MetalWorking Machines
    Last Post: 09-16-2007, 05:57 AM
