586,102 active members*
3,194 visitors online*
    9
    non-metallic liner
    I need information about the manufacturer or suppliers of non-metalic liner for box type cnc machine bed.
    Tariq Fayyaz
    Lahore,PAKISTAN
    Apr 2004
    5737
    Re: non-metallic liner
    Are you talking about Turcite https://www.aetnaplastics.com/products/d/Turcite ?
    Andrew Werby
    Website
    Sep 2005
    371
    I used a flexible pvc shower liner. It goes on the floor before installing the shower. The beauty is it can be lapped and glued as needed.
    I also sloped the platform from back to front and cut a 4" pvc pipe in half to use as a drain pipe for the flood coolant. I glued the material to the drain pipe (which was also sloped).
  1. Guideways liner change in VMC
    By kirit in forum Environmental / Alternate Energy
    Last Post: 05-18-2016, 11:39 AM
  2. Making serrated teeth on metallic surface
    By fredi in forum MetalWork Discussion
    Last Post: 09-30-2012, 02:55 PM
  3. Replies: 0
    Last Post: 12-04-2008, 09:36 AM
  4. CNC for a/c duct liner
    By WMACS in forum Open Source CNC Machine Designs
    Last Post: 10-02-2007, 07:18 PM
