586,655 active members*
3,096 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > Cutting .020 Sheet Aluminum on a CNC Router
Results 1 to 13 of 13
    Dec 2006
    34
    I have a 4'x8' CNC Router. I want to cut parts out of .020 and .024 4'x8' sheets. Can anyone recommend the best hold down method and router bits to use?
    I was thinking of making a vacuum hold down table using pin holes like a air hocky table but is anyone using vacuum hold down on materials that you cut completely thur? In this case the bit would have to cut slightly into the hold down table destroying it over time.
    As far as the bits go, I would like to use the smallest diameter possible and I would assume I have to use a down cutting bit to prevent lifting?
    I just don't know how to get started with this, any help from those who do this for a living would be appreciated.
    Feb 2007
    424
    Quote Originally Posted by Mini-MillX2 View Post
    that would work, some people who do wood use a substrate like mdf, we use a woollike material on out plotter cutters, but I don think that will work. It has to be porous enough(plus maybe drill holes) for the vacuum to work. you can then skim it down as you wear it out.
    You may want to ask in the wood router section and see what they say.
    As for the bit that depends upon your cuts, and if you are doing very small parts you might not have a lot of luck, just remeber the smaller your bit the faster your spindle needs to go.
    chris
    Nov 2006
    251
    I dont know if this will help or not mate,but what i do when making special gaskets out of alluminium or copper is to clamp them between two pieces of mdf or similar material and that works fine for me good luck.greg b
    Jul 2005
    409
    Cutting alum. on router
    Mini-MillX2,
    I cut aluminum on my router, up to 1/4" usnig double-sided tape to my mdf table. as for the bits, I use a 1 flute upshear bit from either Micro100 or Onsrud.
    I do not have a vacuum table yet but this is the way to go for parts that are not too small, or you could make the vacuum table to seal around the edge of the part and use a gasket, so when you cut the material-the cut is out side the gaketed area.
    The industrial routers like thermwood, motionmaster, use mdf on top of the vacuum plenum and pull right thru the mdf.
    Hope this helps,
    Cutmore
    Dec 2006
    34
    Quote Originally Posted by cut more View Post
    Mini-MillX2,
    Hope this helps,
    Cutmore
    Thanks for the information. What bit size ane RPM do you or would you use for thin materials? I can't believe they can pull vacuum thru MDF, but that's what I thought they were doing.
    Jul 2005
    409
    Bit size
    I use an 1/8" @ 22,000 rpm. If I want a really smooth edge I go ~ 10 IPM. with an 1/8 doc. On thin materials you can travel faster.
    I have seen the large routers with vacuum hold down cut mach faster due to no chatter of the material.
    What size are your parts?
    Cutmore
    Dec 2006
    34
    Cutmore
    The parts I want to cut are mostly large parts out of a 4x8 sheet of .020 Aluminum. I don't do any really small parts or artistic type parts.
    Feb 2007
    3
    Look around before buying MDF, you should find some ultra-light MDF, I just went through all this at work, got a new router 3 weeks ago, it's a multicam 3000 series with a 33 HP vacuum, well standard MDF don't work well even with a 33 HP pump, the ultra light works OK on .040 Aluminum or thicker as long as I keep my feeds down under 200 IPM. With my old router, I would use a spray adhesive to glue .020-.125 Aluminum to a sacrificial, I used a product called corex, it's about $10.00 for a 4 x8 sheet. With this setup I would cut with a .125 SF Upcut spiral bit 18,000-20,000 RPM @ 75-100 IPM, .250 SF upcut Spiral bit 18,000 RPM @ 102 IPM. 102 was as fast as the machine would go.
    Dec 2006
    34
    Quote Originally Posted by Greeves View Post
    Great information. What adhesive did you use and how difficult was it to separate the parts from the sacrificial? I tried to look for corex on the internet but I didn't find anything. What type of material and thickness is it? I think initially I'm going to have to go this route instead of using a vacuum table.
    Mar 2007
    463
    For thin material like that I would use an O-flute cutter. You will find tha it cuts clean and will NOT pck the part up from the table.
    Feb 2007
    3
    Quote Originally Posted by Larry83301 View Post
    I'm guessing that would be a straight cutting bit, I may want to try one for thinner alum to try to get my feed speeds over 200 ipm without flinging parts across the room, its kinda funny this new table with the spindle up moves to the next part at around 1600 ipm and if anything has been lifted by a previous cut it don't hesitate to throw parts around, it moves too fast to try to get you hands in there to get things out of the way. I'm sure I'll get things figures out, hell I've only had the thing for three weeks now
    Nov 2004
    53
    You could try our V-Clamps and use face plugs. They are an "off the shelf" method of work fixturing.
    Use the face plugs for grip and through cutting possibilities.
    www.vac-clamp.com
    and look for the CNC information page
    Errol
  1. Aluminum cutting router
    By sdantonio in forum Uncategorised MetalWorking Machines
    Last Post: 03-28-2006, 11:33 PM
  2. Cutting 1/4" aluminum sheet
    By energyforce in forum MetalWork Discussion
    Last Post: 12-01-2005, 08:12 AM
  3. CNC sheet cutting comparisons: laser, router, punch, waterjet, wire edm...
    By InspirationTool in forum Waterjet General Topics
    Last Post: 06-24-2005, 07:22 PM
  4. Having trouble cutting aluminum sheet
    By fastturbovet in forum MetalWork Discussion
    Last Post: 06-15-2005, 04:33 AM
  5. CNC Router cutting Aluminum
    By 2Gs in forum DIY CNC Router Table Machines
    Last Post: 08-09-2004, 02:21 PM
