586,067 active members*
5,231 visitors online*
Results 1 to 8 of 8
    Jul 2017
    15
    Amada Aries 222 Floppy settings
    Hello guys,
    I am new on working with this machine and get stuck all the way with different problems, that I hope someone knows how to solve.
    This is the main issue: saving a file from PC does not get to be read from the Aries. The machine needs to format the floppy disc itself, that it does fine, afther cleaning the wires well. It also copies programs from the main memory that it can be open on the NC, but not on the PC. The same vice-versa. So all the jobs must be done manually entering on the machine. I have read the documentation several times, also service ones, programing ones and did not get the answer. Then I got the file attached, but do not know how to enter the setting menu mentioned.
    Thanks in advance for your patience and help!
    Attila
    Attached Thumbnails Attached Thumbnails 98002 compatibilite 2HD floppy disk 04PD.pdf
    Mar 2009
    101
    Re: Amada Aries 222 Floppy settings
    If you are communicating with RS232 you need configured cable. You also need to configure the HIO board for communication. How do you know the drive is formatting the floppy? Ad a file from your laptop to floppy, put in aries and format. Is disk clean? no files?
    Jul 2017
    15
    If I copy a file from internal memory to floppy (afther formatting it in the machine drive, not before) it appears on the list, on EDIT->I/O->LIST->FLOPPY. But can’t read it on my PC. What is the format that the machine writes/acceptes? .nc?
    Also did’t try the RS232 communication yet. Thanks
    Jul 2017
    15
    I have tryied adding a file from PC to floppy, then formatting it in the Aries, then the floppy is unreadable on PC, it asks for formatting. But returning it to Aries it sees it as formatted and is writable on the machine. So I think the floppy drive is working on the machine.
    Jul 2017
    15
    Quote Originally Posted by AMADAJOE View Post
    Joe,
    Thanks for your help. Still, please give more details if you have about the HIO board configuration and the configured cable? Also I have received the USB comunication device for RS 232 but it receives just empty .txt files and cannot send anything.
    Best regards, Attila
    Mar 2009
    101
    Quote Originally Posted by Kupas View Post
    Joe,
    email me I will send you some info [email protected]
    Jul 2017
    15
    Email sent.
    Jul 2017
    15
    Hi, problem solved in the mean time, but thanks anyway.
    Do you know if this machine has the possibility of RAM lowering? Because it is moving in full course all the time.
    Regards, Attila
  1. Amada Aries 245 Emulator
    By dexyweescot in forum Uncategorised MetalWorking Machines
    Last Post: 10-07-2017, 11:00 AM
  2. Amada Aries 222
    By Kupas in forum DNC Problems and Solutions
    Last Post: 10-01-2017, 06:46 PM
  3. Amada Aries 222
    By Kingofthehobo in forum DNC Problems and Solutions
    Last Post: 12-14-2016, 03:21 PM
  4. Aries Amada 222
    By hari000 in forum DNC Problems and Solutions
    Last Post: 10-10-2016, 08:25 AM
