Re: Fusion 360 or PP tool table
Everything said here about Fusion and PP tool tables is great advice. But I suggest that you watch a few videos on the Fusion tool libaries. What you might get hung up on is the difference between your master libraries and your part libraries. I wont go into detail here since the Autodesk and NYC CNC videos explain it.
One thing I find really helpful is setting up master tool libraries for the different materials I run. They are cloud libraries so I have access to them regardless of the computer I'm on. I have one set up for aluminum and one for steel. As other have said, fusion doesnt care about your tool lengths, but it will tell PP the speeds and feeds to run so having the different material libraries is a huge time saver. Having your tool length and stick out is nice but it doesnt have to be accurate in fusion. As others have said, it will give you an collision indication. In those cases, I always double check the tool length in PP.
Tormach PCNC 1100 Series 3 w/ Rapid Turn, Fusion 360
