586,075 active members*
4,141 visitors online*
IndustryArena Forum > Community Club House > Machinist Hangout > Help with Doosan Puma, need to turn off broken bar feeder
Results 1 to 7 of 7
    We have a PUMA 2500 that has an inoperable bar feeder on it. Does anyone know which bit I can toggle to get the lathe to ignore the bar feeder?
    Apr 2016
    74
    Re: Help with Doosan Puma, need to turn off broken bar feeder
    hi, we do not have to toggle any bit.
    i just dont turn on the bar feeder.
    what is it telling you? i do have a block skip in the program as to not
    let the bar feeder count parts
    The loader has been hooked up for 5 years but not used in the last two. It is causing the Lathe to alarm out. The alarm is 2014 Alarm faults with the loader. I did not find the alarm in the manual. I was assuming it was an optional parameter I could turn off. I suppose it could be wired in to the inputs?
    Apr 2016
    74
    from my experience with ours, if its not on, which it does not turn on with the lathe, it has its own power switch.
    the only times i will get an alarm is if something in the program is calling out a code for the bar feeder.
    that is why i leave it off and block skip the call out for the bar feeder.
    I made a typo its alarm 2041. Book just says same as screen, no help. Our loader comes on or use to when the machine is under power but before the control power is pressed. I am looking at relays now.
    Apr 2016
    74
    when do you get the alarm, when you try to run a program?
    Quote Originally Posted by skywalker4 View Post
    It errors out as soon as the control comes on. We have a call in to our local repair guy, but have not found where to turn it off so the machine does not look for it. I ordered a new power supply for the bar feeder to get the lathe to run. We are running again.
  1. Doosan puma with lns bar feeder
    By frye in forum Daewoo/Doosan
    Last Post: 07-14-2017, 04:29 PM
  2. Buying a used doosan puma 480, puma 800l
    By Michael82 in forum Daewoo/Doosan
    Last Post: 09-05-2015, 01:44 PM
