586,119 active members*
3,325 visitors online*
Results 1 to 6 of 6
    Oct 2005
    105
    RFQ Aluminum pulley flanges
    I need someone to cut out flange rings from aluminum.
    Specs:
    ****NOTE: OD is 3.75 NOT 3.5 inches****
    6061T6 Alum.
    Thickness .060
    OD 3.75 inches (was 3.5)
    ID 2.450 +/-.015
    OD and ID must run concentric within .015
    OD and ID must be round within .015.
    Flat within .010.
    Quantities: 10/25/50 pcs
    Quote price & delivery including shipping
    Required ASAP.
    Email direct if possible....
    [email protected]
    Dan K
    Apr 2005
    86
    never mind...
    Oct 2005
    105
    More Info:
    Tolerances:
    Thickness: +/- .015 inches
    OD: +/-.030
    NOTE:
    OD is 3.75 NOT 3.5......
    My mistake!
    thanks
    dk
    Oct 2005
    105
    RFQ closed.
    Oct 2006
    31
    closed RFQ
    Was this job awarded to this community or was it pulled?
    Just curious!
    (nuts)(nuts)
    SteelCutter
    Oct 2005
    105
    Due to time constraints, it was done in house.
  1. :RFQ: 2 304SS Flanges
    By CarTunr22 in forum Employment Opportunity
    Last Post: 03-06-2007, 04:48 AM
  2. Cutting side flanges off of Kurt-type vise?
    By InspirationTool in forum Work Fixtures / Hold-Down Solutions
    Last Post: 01-05-2007, 07:43 PM
  3. Bonding flanges to a timing pulley?
    By Chris D in forum Welding Brazing Soldering Sealing
    Last Post: 10-01-2005, 02:37 PM
  4. Machining exhaust flanges
    By pauls in forum MetalWork Discussion
    Last Post: 03-15-2005, 06:12 PM
  5. Aluminum Timing Pulley Supplier??
    By hddjohns in forum Community Club House
    Last Post: 08-09-2003, 12:33 AM
