586,121 active members*
3,497 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > Oil leak inside column of VM-2
    Oct 2010
    30
    There is so much oil on the spindle motor inside column VM-2, I can not find where it come from - oil around Tool Reliese Piston, on the motor and fan. Air line has not additional oil filter, but it seems free of oil. Is it comes from spindle lubrication system? Machine is working since 2011.
    Apr 2005
    713
    Re: Oil leak inside column of VM-2
    Bad picture, but if that machine made a lot of mist, that is perfectly normal. My '07 looks the same way, just more dirty.
  1. Best place for Z-axis motor, top of column or inside cowl?
    By slashmaster in forum X3/SX3/G0619/G0463
    Last Post: 01-21-2017, 01:10 AM
  2. mm18 air leak
    By markjb in forum Milltronics
    Last Post: 05-31-2012, 12:54 AM
  3. Air Regulator Leak
    By slideleft in forum Haas Mills
    Last Post: 02-22-2011, 11:41 PM
  4. spindle leak
    By jetflatline in forum Charter Oak Automation Support Forum
    Last Post: 06-12-2010, 07:59 PM
  5. HARBOR FREIGHT small round column mill to a square column conversion.
    By motomitch1 in forum Vertical Mill, Lathe Project Log
    Last Post: 12-01-2005, 05:24 PM
