586,655 active members*
2,233 visitors online*
IndustryArena Forum > CAM Software > SolidCAM for SolidWorks and SolidCAM for Inventor > 2 SolidCam Files open at the same time? .. also Process Templates and Rotation issue
    Oct 2017
    8
    Hello,
    I have a few questions regarding some issues I've come across.
    First question
    ; Is it possible to have two SolidCam parts open at the same time? I've been referencing some settings in parts that I previously made and it's a bit of a pain that I SolidCam closed the existing part in order to open a different one.
    Second
    ; I've been saving process templates for operations which are the same across multiple parts with geometries that are the same but that may be in differing locations. The issue I'm having is that I'm using a Transformation in the process. It's on a CNC lathe, so the operation is carried out at 0, 90, 180, and 270. I've done this through Transformations>Rotate> Delta as a 4-axis transformation doesn't suit due to a reversed tool direction at 90 and 270.
    The process loads fine with the 4 operations but with the rotation missing (the geometry too, but I expect that to a certain extent). It still works but I have to go through the whole transformation process from the start with the 90,180 and 270 operations. Is there a setting I'm missing or is the rotation bound to be lost when starting a new process?
    Regards.
    Oct 2013
    153
    Re: 2 SolidCam Files open at the same time? .. also Process Templates and Rotation is
    Yes it's possible to have two solidcam files open at same time . The trick is you just need to open another SOLIDWORKS window then open a solidcam cam inside that.
    Mar 2017
    24
    When you first load a template there is no geometry associated with the toolpath, so there is nothing for SolidCAM to transform. If you wish to save all your parameters, ie: transforms, you can try using the "Save As/Change Model Reference" method. If you models are almost identical except for one small geometric difference then this is the best way to save all your work from the previous file. You can see how this works in this training video: https://www.youtube.com/watch?v=BtzgeEue8O4&t=129s
    Oct 2017
    8
    Thanks for your help, I just noticed your post.
  1. solidcam simulate 4th axis rotation
    By mycnc2012 in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 05-18-2021, 09:17 AM
  2. Input please - Avg. CAM Process Time
    By Irishness in forum Uncategorised CAM Discussion
    Last Post: 06-17-2013, 05:58 PM
  3. G68 Coordinate Rotation issue...
    By TheDane in forum Fanuc
    Last Post: 03-30-2011, 12:17 PM
  4. Replies: 0
    Last Post: 12-04-2009, 01:01 AM
  5. Replies: 3
    Last Post: 07-27-2009, 09:56 AM
