When I upgraded to the new CNCRP touch plate, I decided to see if I could make a bracket to mount it on the z-axis using existing threaded holes. This allows me to run the connecting cable through the cable track system, and insures that the touch plate is always within easy reach of the Z-axis when zeroing. I just ran it with enough slack to loop around the Y-axis motor so it's out of the way during cutting. Here are some pictures. note that the bracket could be mounted lower on the Z-axis too.
Printed at Shapeways.com . If there is any interest, I can make it available to purchase.
(PS. Thanks to the guys at CNCRP for making the holes nicely spaced (matching the 8020 system))
Attachment 374732
Attachment 374734
Attachment 374736
