586,075 active members*
3,865 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > Machine slot cutting is off
    Jun 2015
    10
    Hi All,
    I recently built my hobby cnc machine and have been using ti to make some brackets. However, I have found that the machine tends to never cut the same line twice...
    I want to cut a piece of 3 mm thick aluminium in a particular shape (see the "Bracket" image). I have set it to cut many small layers which works great (ie there is no gummy up of the bit). The interesting thing is that I have noticed with each layer cut the y zxis cut is off by about 0.5 mm (see the "Cut" image). From the wonderfully straight lines I can tell that the x axis is cutting fine. I thought it may have to do with my clamping. However that does not really explain why it is perfectly straight in one direction. My first hypothesis is that the coupler between motor and ballscrew is flexing too much as the bit moves through the metal, resulting in the stepper thinking it has gone the entire length when it hasn't. But I have the same couplers on all axes.
    Any thoughts as to why it would be doing this and help on how to fix it? I dont really want to have to invest in a closed loop system (I doubt this would solve it anyway if it is flex in the coupler)
    Thanks in advance.
    Dec 2013
    5717
    Re: Machine slot cutting is off
    It looks like the coupling is slipping, the stepper is loosing steps, or the steps / mm is not correct.
    Jim Dawson
    Sandy, Oregon, USA
    Apr 2004
    5737
    It could also be deflection of the tool, combined with some flex in your system. It's only the most rigid CNC routers that are able to cut aluminum reliably. How thick is your tool, and how far does it stick out from the collet? If you put a dial indicator against your spindle and lean hard on the other side of it, when the machine's powered up, is there any change on the dial? What happens if you run the pattern in something a lot softer, like machinable wax?
    Andrew Werby
    Website
    Apr 2015
    113
    Thats definitely just backlash in your system. Deflection of the tool or machine look much differently.
    Luthier/Woodworker/Machinist in NS, Canada.
    Jun 2015
    10
    Thanks for all your comments.
    I finally got around to trying a few things. Turns out the coupler was slipping. The screws had worked loose. After tightening those it cut beautifully! !
    Thanks again
  1. Slot cutting issue
    By hmw000 in forum PhotoVCarve and VCarve Pro
    Last Post: 07-16-2015, 10:29 AM
  2. Slot cutting ramp in and out Help
    By trivette in forum G-Code Programing
    Last Post: 01-22-2012, 04:38 AM
  3. Cutting a slot in a shaft
    By Mogzieno1 in forum Solidworks
    Last Post: 11-18-2008, 07:59 PM
  4. cutting a slot with a t-slot cutter
    By cncuser1 in forum Mastercam
    Last Post: 09-10-2008, 03:02 AM
  5. cutting a slot
    By adamchapman in forum Mastercam
    Last Post: 08-21-2008, 09:40 PM
