586,103 active members*
3,331 visitors online*
Page 1 of 3 123
Results 1 to 20 of 54
    May 2017
    50
    Hitachi Seiki 5NF-800
    I have a Hitachi Seiki 5NF-800 and manuals.
    I help you:
    - I have manuals;
    - I help to fix something;
    - I can help you to communicate CNC with computer by RS232;
    - I’m computer engineer;
    I need help:
    - My Splindle doesn’t work;
    - I have a alarm THAL, I don’t know where;
    Contact:
    E-mail: [email protected].b
    Text message: 561-305-0544
    Cell phone: 561-305-0544
    Hi
    Dec 2009
    539
    Re: Hitachi Seiki 5NF-800
    TH AL is thermal overload if I remember correctly on the Spindle Drive. Take a look to ensure its powered up and in the ready stage
    John
    May 2017
    50
    I think is about my Spindle! Because it’s not move. Tell me more about this! Please. Thanks.
    May 2017
    50
    Someone help me?
    My spindle don’t work.
    I have a SEIKE 5NF-800 ( Fanuc 6T-B).
    I make a lot of test, like:
    1) Oil reserve, its ok;
    2) Sensor door is ok, tested;
    3) The chuck open and closed when the pedal is pressing;
    4) I disconet all communication cables inside the machine, clean whit a product to circuit board, its ok;
    5) The Spindle is not FANUC, is FUJI, and i tested the board and everything ok, its working, no alarm;
    6) Im tested de Power transformer; its ok;
    7) Im tested the Fanuc Power Supply board, its ok, working;
    8) After the main power key switch, have a automatic contactor, but its not inicialize! I made a test, and the hardware is ok; Its need to receive a command to initiate; WHERE?
    9) When start the machine, everything ok, no have alarm.
    10) The star button in DGN 101 bit 2 in 1/0 is ok.
    11) Zero return, ok.
    12) The LEDs on master board is ok, everything OFF.
    13) The LED on Speed control Board is ok, two LEDs in green.
    14) I made a Memory Test when initiate the machine on MODE screen, the first LED on master board blinking, the test ok;
    A tip:
    Before, when the machine work, and you wil go to start a program and this ok, execute. And then, at the next day, if you go to start a diferent program, the machine don’t start, you need to re-open the last program used, start, the machine work, and then change the program to use, start again and the machine go perfect. this trouble is link to a memory, directory, reorganize something????
    DIAGNOSTIC INFORMATION:
    DGN 038, the value is 00010000 - means EMERGENCY STOP.
    DGN 040, the value is 00000111, is ERRO DETECT, C02(30). I tested the cable, its perfect.
    My email: [email protected]
    HELP ME !
    Dec 2009
    539
    Did the TH AL Alarm go away now or is it still present?
    Does the spindle drive Jog at all? If you spin by hand do you get any change in the RPM meter on the control?
    May 2017
    50
    Hi, first my spindle stop a two month ago. Now a have a TH AL Alarm. Spindle don’t move in any mode. Just by hand, and when I put the multimeter I see some charge. Can you help me?
    Dec 2009
    539
    TH AL is the therma overload on that Fuji Drive - there should be an LED indicator for it. Please confirm. What is the model of the Fuji Drive - is it a DSR or FSD series?
    May 2017
    50
    In spindle board don’t have Leds on! Just in rele board, the name of rele on is TH AL, I sow I’m manual. Below my spindle model. Thank very much for you help me!
    May 2017
    50
    May 2017
    50
    If you make this machine work again! I will send a whiskey bottle! Sure!
    May 2017
    50
    Hey John! Help me! Please!
    Dec 2009
    539
    Send a picture of where you are seeing this alarm - I am not sure what you mean by Relay Board
    john
    May 2017
    50
    May 2017
    50
    Hello! Can you help me???
    Dec 2009
    539
    Does this machine have a tailstock on it?
    May 2017
    50
    Yes! There is!
    May 2017
    50
    Dec 2009
    539
    Quote Originally Posted by JeanLuiz View Post
    Move the tailstock all the way forward then all the way back a few times and make sure the machine knows it's home
    John
    Sent from my SM-G930V using Tapatalk
    May 2017
    50
    Just this part is automatically:
    May 2017
    50
    Hey my friend! I still need your help!
Page 1 of 3 123
  1. Hitachi Seiki HT 20
    By aussiejoeblow in forum Mori Seiki lathes
    Last Post: 09-14-2018, 10:07 AM
  2. Did Mori Seiki Buy Hitachi Seiki?
    By Billet Sean in forum Mori Seiki lathes
    Last Post: 05-05-2011, 04:12 AM
  3. Need Help Hitachi Seiki V-40
    By kenwalus in forum Uncategorised MetalWorking Machines
    Last Post: 08-28-2009, 02:36 PM
  4. Hitachi Seiki
    By mroy0404 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 05-08-2007, 05:28 AM
  5. Hitachi Seiki
    By cre8tunes in forum Community Club House
    Last Post: 11-18-2006, 02:40 AM
