586,602 active members*
3,535 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > Haas EC-400 APC lift cam may be damaged.
    Sep 2007
    122
    Exclamation Haas EC-400 APC lift cam may be damaged.
    Looking for help finding haas 2005 parts for an EC-400. The lift on the APC will not go all the way up and I think it is the cam on the inside. It looks repairable from the manual but I am looking for parts.
    Any help would be appreciated.
    Oct 2017
    Re: Haas EC-400 APC lift cam may be damaged.
    Search | Haas Parts | Genuine OEM Haas Automation® Parts Factory-Direct
    Or just go on haas arts webside & type your machine serial number.
    You're not getting any alarms?
    Sep 2007
    122
    The 3 balls had major contamination. Pounds of rust and dust in the cam tracks. While we had it open we replaced :
    (1) 51-0152 BEARING TAPERED ROLLER
    (3) 59-0616, BALL 1 7/8 APC
    (1) 20-2110A CAM , $895.00
    Parts ordered from Gerotech - one day delivery - THANKS!!!
    Problem solved mechanically. We are now trying to get the APC (W axis) to home correctly.
  1. 4" lift on a HAAS GR-712
    By RH_Machine in forum Haas Mills
    Last Post: 06-27-2016, 10:44 PM
  2. How to know if a resolver is damaged?
    By jerodor in forum Servo Motors / Drives
    Last Post: 07-16-2015, 07:33 PM
  3. damaged cnc
    By mtushmoo in forum Want To Buy...Need help!
    Last Post: 01-12-2013, 03:06 AM
  4. Vertical lift platform-vertical lift table in China
    By mornlifttable in forum News Announcements
    Last Post: 06-28-2012, 04:30 AM
  5. damaged 320's
    By dewme5 in forum Gecko Drives
    Last Post: 11-28-2007, 03:50 AM
