586,104 active members*
3,252 visitors online*
Results 1 to 8 of 8
    Jun 2016
    184
    Tormach 440 Part Success
    For the most part I post here when I have problem with my 440, but now that is up and running again, here is part I just finished that I am really happy with how it came out. The size of it is about 3.54" wide, 4" long and 1.25" thickness. Material is aluminum 6061. All machined on 440, couple of holes hand deburred otherwise untouched. Even the big threaded hole was spot on...
    Mar 2012
    378
    Re: Tormach 440 Part Success
    Looks great. How long did it take? I assume you used a thread mill?
    Jun 2016
    184
    One side took about 42 minutes other about 12. Manual tool changes, no power draw bar yet. For prototype parts this works. On side note I used .75" Shear Hog for roughing out everything. That worked out so great, I love Shear Hog! Reason I like it though is because it creates very manageable chips which are easy to clean and also because it throws chips very far which works excellent with FogBuster and they all get out of the pocket. No need to remove chips from part while its machining.
    Mar 2009
    1863
    Nice looking part. What did you use to program it?
    You can buy GOOD PARTS or you can buy CHEAP PARTS, but you can't buy GOOD CHEAP PARTS.
    Jun 2016
    184
    Quote Originally Posted by Steve Seebold View Post
    Thank you. All done in Fusion 360.
    Jul 2017
    13
    Nice work!
    What did you use for the finish profile?
    Did you use the carrier method in order to complete the entire profile in the first op?
    Jun 2016
    184
    I used Talon jaws and completed entire bottom side (first photo) and outside profile in first op. I used 1/2" Variable Flute Lakeshore Carbide for finishing. Reasoning was that I wanted stiffest tool to get best side wall finish and that worked out great. I have some parts machined by the pros on big VMCs and finish I got on Tormach is just as good. Very happy with what I was able to get out of this little machine.
    Oct 2011
    134
    Nice work- thanks for sharing!!
  1. Ran my first part on my new Tormach today
    By CadRhino in forum Tormach Personal CNC Mill
    Last Post: 01-30-2014, 01:10 AM
  2. Tormach Survey - Part Two
    By ljh34481 in forum Polls
    Last Post: 04-23-2012, 05:53 AM
  3. Tormach Survey - Part One
    Last Post: 03-17-2012, 07:49 PM
  4. New Tormach makes my first part!
    By cheetahcnc in forum Tormach Personal CNC Mill
    Last Post: 03-09-2012, 12:01 AM
  5. Success. Machineable Wax Part II
    By charper in forum Education - Teachers and Students Hangout
    Last Post: 03-22-2007, 10:12 AM
