586,584 active members*
2,714 visitors online*
IndustryArena Forum > CNC Electronics > CNC Machine Related Electronics > 4 and 2 pin header on ubiquitous "5-axis break out board"?
Results 1 to 7 of 7
    Sep 2006
    247
    I have one of the ubiquitous "5-axis break out board" with screw terminals and 2 or 4 pin headers. What are these headers called, and where can I buy the female plug for this header? Not enjoying using the screw terminals.
    Jun 2005
    1730
    Re: 4 and 2 pin header on ubiquitous "5-axis break out board"?
    You can find those connectors at Digikey.com
    Check the spacing from one pin to the next, most of these boards us .100" spacing but some also have metric spacing. Take a measurement tool and then you can search on digikey and find all the matching plugs.
    Russ
    Sep 2006
    247
    @cncman172
    I hate to seem so ignorant, but I don't have enough of the nomenclature to even do a search on such a vast site. Do this style of connectors have a name? I can measure that the pins are 2mm apart, but what about the actual plug? I see a lot of things with little snaps attached, do they fit these rectangular plugs with notches cut out? With so many similar designs, I don't know what fits this particular header. What search terms do I use to find this?
    Thanks!
    Dec 2012
    203
    just do a search on Aliexpress , Ebay or a search machine and search for " connector 4 pin 2mm "
    You will find something like MCIGICM 2000pcs female material PH2.0 2mm 4 pins Connectors Leads Header Housing PH-Y Also buy the pins that are needed
    Toin
    Jun 2005
    1730
    rlrhett,
    You did not have a close imagine of that particular board, so it was hard to tell but here are some example connectors with 2mm spacing. At the bottom of the first page you can find matching plugs. This should point you in the right direction.
    Russ
    https://www.digikey.com/product-deta...51-2-ND/926657
    http://www.jst-mfg.com/product/pdf/eng/ePH.pdf
    Sep 2006
    247
    That’s it! Tanks a million.
    Sep 2017
    14
    https://rover.ebay.com/rover/0/0/0?m...2F272725388633
    Mine was 2.5mm but I found a whole kit on eBay that worked out well for me
  1. "B" Axis Break Issue
    By diesel68 in forum OKK
    Last Post: 11-08-2016, 06:45 PM
  2. Need help working out feed rate for "C" Axis and "Z" axis simultaneously.
    By Jonaldhinio in forum Australia, New Zealand Club House
    Last Post: 08-12-2014, 09:27 AM
  3. "Breakout board & motor controllers" v "Stepper motor driver controller board"
    By atkinsonp in forum CNC Machine Related Electronics
    Last Post: 10-21-2013, 09:41 PM
  4. X Axis "Goes Off Pattern", "Awry", "Skewed", "Travels"
    By DaDaDaddio in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-06-2013, 09:59 AM
  5. Replies: 4
    Last Post: 12-17-2011, 04:27 PM
