586,913 active members*
3,040 visitors online*
Thread: Micro slot
    Jan 2017
    13
    Micro slot
    So looking for any ideas on how to machine a slot .25mm wide by 8mm deep in alum. Not thru so cant wire it. Any ideas? Can they laser to depth?
    Nov 2008
    110
    Re: Micro slot
    Slitting saw?
    Mar 2018
    12
    Re: Micro slot
    Hey, did you ever figure this out? I'm trying to cut micro fins for an aluminum heat sink and am considering the same thing.
    Jan 2017
    13
    Re: Micro slot
    I ended up getting the part revised and was able to use a slitting saw.
  1. How to slot a rectangular slot with convex bottom ?
    By bbwilliamson in forum Mach Mill
    Last Post: 04-19-2016, 12:25 AM
  2. EG micro
    By turpija in forum Epoxy Granite
    Last Post: 03-02-2016, 12:13 AM
  3. one slot is coded other slot is not there
    By cwaugs in forum Uncategorised CAM Discussion
    Last Post: 05-06-2011, 03:00 AM
  4. cutting a slot with a t-slot cutter
    By cncuser1 in forum Mastercam
    Last Post: 09-10-2008, 03:02 AM
  5. Replies: 7
    Last Post: 04-12-2007, 03:00 AM
