586,042 active members*
3,657 visitors online*
IndustryArena Forum > Laser Engraving and Cutting Machines > Laser Hardware > Laser power supply MYJG50W, I have burned TWO in one week... No idea why
    Feb 2017
    Question Laser power supply MYJG50W, I have burned TWO in one week... No idea why
    Hello guys!
    Im using classic "blue china laser cutter",
    last week my power supply dead because of burnt isolation on ceramic transformator:
    okay, **** happens I thought, and replaced burnt one with a brand new from the box...
    AFTER 6 hours it has gone without ANY visible trace of burning or any other defects.
    Green power LED is On, but it gives no energy to laser tube at all.
    So I have the last one MYJG50W installed, it works for now, but I am not sure if it will live for a long time.
    Found this video about conductive water, and leakage of current because of this
    https://www.youtube.com/watch?v=si7VySd86J0
    Im using just a tap water for freeze with a bid of chloride to kill algaes. Can this cause an issue because of higher conductivity of "chlored" water?
    Yep, I got a slight discharge touching water in freezer.
    Also, during a cut I can clearly hear electric bzzzt sound from power supply unit, is it OK? It seems this sound was present always.
    If someone had such experience, please share it with us.
    Jan 2018
    Re: Laser power supply MYJG50W, I have burned TWO in one week... No idea why
    My first MY JG-50W power supply on a 50 W CO2 laser failed without burning, and it costs 10% of the entire machine cost!!!
    Let's see how Chinese Customre service operates...
  1. Burned Gecko G540- Power Supply or DB9 cables?
    By huh2 in forum Gecko Drives
    Last Post: 01-16-2015, 04:58 AM
  2. Power supply idea
    By Truss-rod in forum DIY CNC Router Table Machines
    Last Post: 10-28-2009, 03:44 PM
  3. Power supply and computer in same case. Bad idea?
    By TXFred in forum CNC Machine Related Electronics
    Last Post: 10-23-2009, 11:07 PM
  4. POWER SUPPLY IDEA!
    By albertsteptoe in forum CNC Machine Related Electronics
    Last Post: 12-06-2008, 05:08 PM
  5. Cursader Series M power supply burned..
    By Danii in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 11-28-2006, 02:44 PM
