586,123 active members*
3,454 visitors online*
Thread: Low cost ATC
Results 1 to 11 of 11
    Low cost ATC
    I wanted an ATC but Smithy didn't offer one for the MX200 Talon. The "Rack" type hogs some machining real estate so that had to go. Here's what I did. Easy.
    Smithy Automate MX200 mill, CNC Masters 1440, CWI Professor CNC Router, various other junk
    Jan 2016
    386
    Re: Low cost ATC
    I like your ATC. Any video's of it in action? Looks like you are running a commercial grade controller and not Mach3 or PathPilot.
    Re: Low cost ATC
    Hi - If you click on the photo you will go to my web site where the video is. It would be easy to make this work with Mach 3 (easier than the Siemens controller).
    Cheers
    Jan 2016
    386
    Re: Low cost ATC
    Very nice. I have a Novakon Pulsar and looking for a simple ATC. I am using PathPilot for control.
    Steve
    Re: Low cost ATC
    Do you have a power draw bar?
    Jan 2016
    386
    Re: Low cost ATC
    Yes, I have a PDB similar to Tormach's.
    Steve
    Re: Low cost ATC
    What type of Tool Holders?
    Jan 2016
    386
    Re: Low cost ATC
    Tormach TTS type tool holders.
    Re: Low cost ATC
    Should work perfect.
    Jan 2016
    386
    Re: Low cost ATC
    Tim, are you using a work offset for your first tool location then offsetting from there for the other three tools?
    Steve
    Re: Low cost ATC
    Steve - In my application the Sinumerik 808D control has provisions for 4 "Fixed Position" variable sets (X,Y,Z). Each set is a tool pocket location. The Tool Change macro logic figures it all from there. Work offsets would work just as well.
    I assume you can orient the spindle on your machine.
    Bob J
  1. T/C..Cost
    By gabedrummin in forum Bridgeport / Hardinge Mills
    Last Post: 01-26-2015, 04:21 PM
  2. How much does MC cost???
    By SDK73 in forum Mastercam
    Last Post: 08-24-2009, 02:57 AM
  3. How much would this cost?
    By SRT Mike in forum Moldmaking
    Last Post: 07-20-2008, 12:40 PM
