586,060 active members*
4,160 visitors online*
    Aug 2008
    4
    small hole in thin metal
    Hello,
    I'm looking for suggestions for drilling a 0.012" hole in 0.001" brass or SS. The stock is 0.375" diameter. I'm able to drill holes in brass with a circuit board drill in my Aciera high speed drill press but can't seem to eliminate the feathery burrs that result without a lot of tedious hand work Perhaps a different type of drill. Maybe SS would be better. Or maybe a reamer for the final diameter. And of course holding the part is a challenge. Does anyone do this consistently with success?
    Dec 2013
    5717
    Re: small hole in thin metal
    Punching that hole would be a better choice. With material that thin you could mount up the punch & die in a drill press or milling machine, you wouldn't need a punch press.
    Jim Dawson
    Sandy, Oregon, USA
  1. Mixed laser cutter for thin metal and thick non-metal materials
    By stylecnc in forum News Announcements
    Last Post: 04-18-2016, 01:45 PM
  2. Thin stainless steel laser cutting machine for metal and non-metal materials
    By aaronhernandez in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 01-04-2016, 03:45 AM
  3. Thin metal laser cutting machine- CHEAPEST metal laser cutter
    By Gweikelasers in forum News Announcements
    Last Post: 03-06-2013, 10:08 AM
  4. Thin Metal Resource
    By toddlock in forum Want To Buy...Need help!
    Last Post: 12-13-2012, 03:48 PM
  5. Thin sheet metal
    By itsme in forum Welding Brazing Soldering Sealing
    Last Post: 03-01-2005, 10:24 PM
