586,432 active members*
4,151 visitors online*
Results 1 to 9 of 9
    Mar 2008
    82
    Displaying number of passes
    Morning all
    Is there a way to get PathPilot to display where it is in a threading cycle - X of Y passes? Would be nice to have that below the DRO.
    Apr 2013
    1788
    Re: Displaying number of passes
    Mill or lathe?
    With a little editing of the gcode you could display whatever on the Status panel or, if you are not using the 4th axis, in the A-axis DRO.
    Mar 2008
    82
    Lathe. Can't see how you edit the code to show it as it uses a canned cycle
    Apr 2017
    158
    The meta-solution is: don't use canned cycles. There's nothing you can do with canned cycles that can't be done better with parametric subroutines. I (with help from Ken Strauss) have been working on a set of such routines for mills, but the same principles would apply for lathes. There's no free real estate on the PathPilot screen, but it's straightforward to use the A-axis DRO -- assuming that you don't actually have A-Axis hardware -- to serve as a sort of progress bar.
    The stuff I've been working on is not quite ready for prime time, but you can get its flavor from this document and this sample subroutine.
    Mar 2008
    82
    The lathe PathPIlot screen has plenty of real estate available, and there are only the two DRO's for X and Z. Adding the number of passes and where you are in that cycle would be easy for them to do.
    Apr 2013
    1788
    I'm curious why this information would be particularly valuable. Surely, except in the initial debugging stages, you will be letting the operation run to completion. Based on elapsed run time (I assume that is displayed in Passport lathe the same as in the mill version) or visual inspection of the thread it should be rather easy to estimate progress in production.
    Mar 2008
    82
    With coolant, it's not easy to see where you are in the process. With common threads, I like to cut them to about 75% and then allow a die to do the rest - I think the result is better.
    Apr 2013
    1788
    I do similar things on my manual lathe. Can't you modify the gcode to terminate after 75%?
    Mar 2008
    82
    Quote Originally Posted by kstrauss View Post
    I can specify a larger x-end in the Conversational tab to achieve it
  1. Number of passes on a lathe
    By juwyro in forum FeatureCAM CAD/CAM
    Last Post: 09-09-2017, 12:16 PM
  2. Baltic Birtch Number Of Passes
    By 2_many_hobbies in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 12-04-2014, 11:50 AM
  3. Replies: 3
    Last Post: 10-20-2014, 02:21 PM
  4. G76 Number of Passes
    By eliot15 in forum G-Code Programing
    Last Post: 04-09-2011, 12:51 AM
  5. Roughing Passes Exceeding Finishing Passes
    By phoodieman in forum Mastercam
    Last Post: 03-01-2009, 01:21 PM
