586,075 active members*
4,261 visitors online*
Results 1 to 6 of 6
    Jun 2006
    22
    CH-VMC 500-Mitsubishi 60S
    Dear all .
    I'm Hung from Viet Nam. I have a milling machine CH-VMC 500 with S/N 04025001.
    This machine use Mitsubishi 60S Controller.
    Now this machine is not working, it indicate error "NO PLC". The Spidle or axes can not move.
    Please help me to solve this problem.
    Thank you for your support.
    Best Regard.
    Viet Hung
    24221
    Sounds like the ladder needs re-loading. If it is not on disk, it would have to be loaded manually.
    Al.
    Albert E.
    Jun 2006
    22
    Thank you very much!
    Please show me the way to check the ladder Plc file if it is on disk.
    Show me the way to re-load step by step please. I have not document.
    Best Regard.
    Thanhct.
    24221
    The Mitsubishi site has all the manuals MEAU.COM
    http://www.meau.com/Files/BNP-B2269.PDF
    Al.
    Albert E.
    Jun 2006
    22
    Thank you for your support ! I found document BNP-B2269
    Jun 2006
    22
    I need help again !
    I read the manual about Mitsubishi M60 and I known it doesn't hard disk. I found memory cassette:FCU6-HR451 for maintenace.
    The manuals show me the way to backup and restore parameter but
    I can not find the way to restore PLC program.
    Please help me !!!
    Best Regard .
    Thanhct.
  1. Posprocessador Mitsubishi
    By Vinicius in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 02-27-2007, 10:07 PM
  2. Mitsubishi Waterjet
    By Elsie Green in forum Waterjet General Topics
    Last Post: 02-14-2007, 05:47 PM
  3. About fed up with mitsubishi drives
    By MDLang in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 01-03-2007, 12:08 AM
  4. mitsubishi encoder
    By rosli in forum CNC Machine Related Electronics
    Last Post: 01-30-2006, 01:13 AM
  5. Mitsubishi Control help
    By justin in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 03-15-2005, 01:06 AM
