586,121 active members*
3,148 visitors online*
    Jun 2004
    24
    Mazatrol T Plus thread cycle in synch?
    Is it possible for the spindle to loose timing after threading?
    We ran an OD thread then after cycle was complete, we measured the part, made an ajustment in X axis in the tool data, ran it again and it's noticably shifted (out of time with original cut, basically scrap now)
    How do you make adjustments to the size while still in chuck?
    It's programed in Mazatrol, QT 15N lathe, It's a stepless spindle I'm thinking.
    Feb 2005
    376
    I've never had an unsolvable problem with it double threading after an offset.
    Did you change your SFM, or spindle speed before you ran it again? The acceleration of the Z axis will screw you up. I learned that one real quick.
    The other thing that has happened is the operator who knew they should check the thread before it came out of the machine, took it out anyways, then stuffed it back in.
    Jun 2004
    24
    Changed sfm
    Yep, Changed sfm. I was thinking about the manual machines in the shop, I can change rpm as long as I dont take out the feed rate levers etc... Any worries about rotating part then (still clamped in chuck) while checking thread etc?
    thanks,
    Steve
  1. Mazak M-4 Mazatrol T2 and mazatrol Cam T2 operating manual in english
    By tuanpq in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 07-09-2021, 04:06 PM
  2. g76 thread cycle
    By warcnc in forum G-Code Programing
    Last Post: 02-03-2013, 11:32 PM
  3. G76 Boring Cycle
    By Gorrell in forum G-Code Programing
    Last Post: 01-25-2007, 10:22 PM
  4. Programming thread mill cycle
    By squirrelledm in forum MetalWork Discussion
    Last Post: 08-08-2006, 12:31 PM
  5. slaved motors aren't working in synch
    By axisdd in forum DIY CNC Router Table Machines
    Last Post: 03-15-2006, 08:59 PM
